Mudflaps?
Mudflaps?
Does anybody know were you can get some cummins mudflaps other than at www.powerstore.cummins.com?All they have are the dodge and cummins ones.And they have some cool ones with the cummins ''C'' in white but they are for semi's.I want the same ones or something similar but to fit a 1 ton truck.Any ideas?
Like these?
I just got the smaller of the two "semi" flaps they sell, then cut them down to fit.
Just make sure you add some anti sail weights to the bottom to prevent this
You'rs being a dually, won't have to trim as much off, and might have to fab up some way to hang them,
I just have mine bolted to the inside rear of the fender
phox
phox
Sweet,I thought of that but I didn't know if it would turn out or not.But I guess I will try it.Looks cool. How much did you cut off the sides?I really like the white ones.The red and blue dodge/cummins ones just don't do it for me.
I must have taken around 2 inches off each side and around 4 off the bottom.
Been putting off getting a new set, as my saw walked out of my garage without permission, just got the replacement for christmas.
phox
phox
I use two full sets, one ahead of the duals and the other directly behind. On my older CTD, I put them on angle irons and welded it to the frame behind the exhaust. Never had a problem with meltdown. They're about 3" off the ground. And, I bought them from Cummins.
Just took mine off the other day, one by choice and the other $$. If you put them on, DO NOT put them where they can get in the tire when backing up. I was in 8-10 inch mud, heard a loud snap, and now get to fix the dually fender.
Ed
Ed
brillmtb
27
04-16-2004 08:25 PM
bryan5791
14
12-29-2002 10:25 AM
