mitchell gear splitter
Old 01-14-2008 | 07:36 PM
99globalwarmer's Avatar
hey guys went to pick and pull and found a mitchell gear splitter series 150, model 2000a on the back of a five speed ford. does anybody have any info i would like to use it in the 92 its all aluminum. anyways if anybody has any info please educate me.
Old 01-14-2008 | 09:07 PM
dv_shane's Avatar
they made them in under\overdrives in different ratios the 2000 is rated lbs. they are out of ca. i think you can write or call them and find out about it. the one i had you had to be stopped to shift it back to underdrive. but you could go from under to overdrive without stopping.
Old 02-03-2009 | 12:04 AM
Bogurt's Avatar
the model has a 1 to one ratio as well as an overdrive ratio. the 2000 series is rated to 20000gvwr
Old 02-03-2009 | 12:05 PM
enafzige's Avatar
^^^^^ Correct. The model 2000 signifies a 20,000 lb GCWR. The "a" part means it's set up as 28.6% overdrive and 1:1 direct.
Assuming you have 3.73 gears, this would effectively give you a 2.66 rear end when the Mitchell OD was engaged.
Their phone number is 1-800-859-2088.
--Eric
Old 02-03-2009 | 12:25 PM
infidel's Avatar
Why would you want one?
More weight and more frictional losses will equal less mpg.
Are parts even available for them anymore?
I thought they were antiques.
Old 02-03-2009 | 04:21 PM
enafzige's Avatar
You would want one because they were arguably the most robust OD units ever produced.
More weight (84 lbs for the largest 35,000 gcwr unit) is not very significant. The frictional losses are negligable compared to fuel mileage savings of lower rpm. Moreover, engine longevity and lower noise cruising are some other benefits.
Some parts are still available, some aren't.
The units made for Dodge trucks were last produced in about 1995. I don't know if that makes them antiques or not. Mitchell Manuracturing does make a variety of OD units for antiques though! In fact, there is such a market for them, they are currently about 8 weeks behind in production!
--Eric
Old 02-03-2009 | 05:02 PM
Bluedually4x4's Avatar
Because if you have 4.10 gears and don't want to change them out is why some one would get an auxiliary transmission or an overdrive unit.
Old 02-04-2009 | 12:15 PM
enafzige's Avatar
__________________
...and it lets you keep your 4.10 gears for when they're really needed, and have a economy rear end for when unloaded!
--Eric
Robofig
12-17-2011 07:05 PM
Rednecktastic
13
06-06-2009 10:51 AM
Racing_Joe66
06-12-2006 08:00 PM
ridofpwrstroke
07-08-2003 05:51 PM
Hummin Cummins
12-25-2002 12:29 AM
Quick Reply: mitchell gear splitter
