Light duty cummins
Light duty cummins
I just read this and and was kinda disappointed, what do you guys think. Oh sorry if this has already been posted.
"Cummins is working on a 4.2 L V6 and 5.6 L V8 for use in Dodge trucks in the 2010 timeframe[1]. This future engine family uses an aluminum head with 4-valves per cylinder and overhead cams on a thin-wall iron block. High-tech variable-nozzle turbochargers and Piezo-electric direct injection will also be used. The V6 is specified at 190 hp (142 kW) and 455 ft·lbf (617 N·m) and will compete with Ford's 4.4 L AJD-V8, while the V8 produces 260 hp (194 kW) and 597 ft·lbf (809 N·m) and will take on the current Ford Power Stroke and GM Duramax V8s."
Article is definitely stretching things... those engines are not destined for the 2500 and 3500... the new 6.7L is already 2010 emissions compliant. Those two engines are going into the Durango and Ram 1500...
I still wonder though why they are going to a V configuration for those. Is the 4bt that much lower in power or harder to make meet emissions? Seems that they would stick with a known quantity. . . .or maybe they just think they general public won't like a straight engine.
These new engines are going to be much more modern than a 4BT. Lower and lighter. Trying to sell a modern pickup with a heavy 4 cylinder that barely fits under the hood vs. a modern 6 cylinder would be hard. I'm not knocking the 4BT, but that may not be the place for it. Also, the 1500 has independent suspension and, at least on the Dakotas, the differential mounts on the engine. Things could get a bit crowded in there. The V6 configuration is a bit hard to accept though. An inline 5 would be excellent but won't market like a V6, and with the V6, you can cram more displacement into a shorter engine.
If someone buys a light duty pickup they are not interested in hauling the heaviest load up the steepest grade at the highest speed. Economy and quiet are more the theme. I would trust any engine Cummins put on sale and light Diesels have been proven to be reliable. There is a market for them.
Wetspirit
Wetspirit
I suspect that a 4BT would not provide a pleasant driving experience for most consumers. Diesels are going to have to mimic the operating characteristics of gasoline engines for them to really catch on with the average driver. Quieter, higher revving, wider powerband. More focused on daily drivability than raw torque and towing power. Kind of like the Duramax.
not at 260hp.... the current DMAZ is at 360.... Dodge would be laughed out of the room bringing 100 less ponies to the table.
I won't be laughing, I'll be standing on my chair and cheering. And I'll also be wondering what took so long
Wetspirit
