Injector Pop Tester
Injector Pop Tester
Have any of you built a Pop Tester?
I made one but can't find a grease gun that is tight enough to pump diesel. The new grease gun that I bought leaks by real bad. So I tried a few of my old grease guns. One of them will make and hold 3000 psi but it leaks in another spot.
Any ideas about what I can use for a pump?
Thanks,
JP.
Thanks,
JP.
Thanks for the help guys.
I got lucky this morning. The nearest Princess is an hour away so I went to the local farm supplier to see what they had. In the hydraulics recycle pile I found a Enerpak hand pump that the cylinder was no good on. $65 later I brought it home and bingo, the pump works great, no leaks, no problems. It is rated 10,000 psi. It works way better than a grease gun because it holds the pressure until you release it with the valve that would normally let the jack down.
In fact, the set up I made is way heavier duty and works better than the factory made tester that my neighbour has.
Thanks again,
JP.
Thanks again,
JP.
Haulin_in_Dixie
09-17-2005 11:36 PM
