how to plumb auxillary tank?
I just ran mine to the nipple on top of the tank. all gravity feed, my transfer tank is 50 gallons and i have spilled before but not that much. when your on a trip you stop after about 500 miles of driving open the tank. I drive for about 1 1/2 or so stop again then i'm good for another 500 miles or more. then open it again and leave it open until I fill up next. I get about 1350 miles per fill up.
As for the D.O.T. issues all semis gravity from one side tank to the other to keep them equal, they have a crossover line on the bottom of the tanks to equalize them, the rule is " A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector" if you want to read the DOT rules..
http://www.fmcsa.dot.gov/rules-regul...csr/393.65.htm
Here's one way to do it:
http://66.17.171.114/PhotoAlbum/Cars/Pics/CTD_64.jpg
http://66.17.171.114/PhotoAlbum/Cars/Pics/CTD_65.jpg
http://66.17.171.114/PhotoAlbum/Cars/Pics/CTD_66.jpg
http://66.17.171.114/PhotoAlbum/Cars/Pics/CTD_67.jpg
I used two selector valves. With the front selector I can run on either main or bed tank. IP return is always to the stock tank and takes about 100 miles to re-fill, so have to watch the gauges while running on the bed tank. I can select to pump it out to whatever with the other selector mounted in the toolbox, using a Holley black pump mounted on the side of the toolbox for that function. Going to pick up 50 gal. of kerosene for the heating stoves tomorrow.
ok so far i am not sure if it is legal in the state of georgia. would federal law and state law be different? my tank is a big L shaped 95 gal tank, which i added a chest tool box to.i also have a electric transfer pump, just like at a gas station on the passenger side. on the drivers side at the bottom of the tank there is a threaded bung with a bolt in it now so it won't leak. i guess this is so you can plumb it into the factory tank. if i put a shut of valve off of that bung and just ran a fuel line to the tank, could i leave it open on long trips so i could run of 130 gallons? would it spill?
I have a 78 Gal. transfertank in mine. I used a ball valve to let me isolate the tanks so I can change the 10 micron filter w/o having the aux tank empty. I also used an electric tank selector valve as a shutoff while on the road. when the power is on it transfers, and while off it shifts to the other port which is blocked off.
I want to find a sensor to install in my tank so I can get rid of the gravity feed system and not have to worry about overfilling the stock tank.
Ram1999
12-19-2006 12:50 PM
CSAGrey1
22
09-17-2006 09:19 AM
Dieseljunkie
08-17-2005 07:54 AM
