Sponsored by:
Sponsored by: CARiD
View Poll Results: You are buying a used CTD and don't mind if the oil is changed every...
100, 000 miles?
0.98%
50, 000 miles?
0
0%
25,000 miles?
2.94%
10,000 miles
25
24.51%
Per the CTD recommendations
73
71.57%
Voters: 102. You may not vote on this poll
How often do you change oil?
Old 02-19-2005 | 11:50 AM
  #46
jtb51b's Avatar
Oil and filter every 5 k
fuel filter every 10k
on my gasser
oil and filter 3 times every 10k ----3k-6k--0k
fuel filter--20k
distributor cap, rotor-- 10k (dang chevy)
Old 02-19-2005 | 02:03 PM
  #47
mr T's Avatar
twice a year...i use it only as an everyday driver...put 20 000kms on it a year...i add a bit every couple months cause the turbo eats it
Old 02-19-2005 | 05:40 PM
  #48
large_marge's Avatar
i change mine ever 4 months, sometimes longer if it is a low mileage 4 months
i'm pretty surprised how few people go by time elapsed rather than mileage.
Old 02-19-2005 | 05:51 PM
  #49
Originally posted by joefarmer How are y'all claiming to have semi-clean oil at changes? I run 3k mi changes and my oil is very, very sooty & black by the first fuel fillup ~300mi
the eye is a very poor insturment to measure the quality of oil. just cuz it's black doesn't mean it isn't working
Old 02-19-2005 | 08:19 PM
  #50
Equalizer 2's Avatar
Every 5,000 with Valvoline Premium Blue with Statopore filter.
Fuel filter every other oil change, also Fleetguard.
Currently have less than 11,000 miles on the truck.
Old 02-20-2005 | 12:46 AM
  #51
joefarmer's Avatar
Which is why I stated "I sent in a sample to be analysed over the last change. Just waiting on the results now and I'll let you know what type of particulate matter I'm seeing."
I want to see if black oil = particulate matter. It's been 6 days since I sent the sample in... How long does it normally take?
brandon.
Old 02-20-2005 | 01:45 PM
  #52
cethane's Avatar
I change mine at 6k when running dino rotella and at abot 10k when running synthetic rotella in the winter.
Old 02-20-2005 | 09:36 PM
  #53
DZLPWR's Avatar
Rotella at 5k
Fuel filter at 10k
Nice and simple
For me its not realy the engine im worried about using higher mileage oil, its the turbo using the oil supply that is 5k old. I like to keep it happy at 150,000 rpms.
Old 02-21-2005 | 02:59 PM
  #54
jlells01's Avatar
'98.5 24-Valve:
Delo 400 or Delvac 1300 15w-40 CI-4 PLUS and TSB 09-004-01 approved Purolator filter
on O.E.M. recommended OCI's.
Old 02-21-2005 | 03:05 PM
  #55
Saxet Nomad's Avatar
I'm changing mine every 5000 right now using dinosaur oil, and I'm about to use Royal Purple and change every 10000.
Old 02-21-2005 | 04:40 PM
  #56
perkins's Avatar
I change mine at 20.000 I use Champian Allfleet T 15/40.Oil samples come back servicable each time. I send the samples to Cat in St. louis takes about 10 to 14 working days.I have 2 ph8a Luberfiner oil filters on the motor.
Old 02-21-2005 | 05:26 PM
  #57
induchman's Avatar
I change per CTD specs: 7500 miles unloaded, 3750 towing.
Old 02-21-2005 | 06:23 PM
  #58
N.Johnson's Avatar
Ya I know it is apples to oranges but a buddy had his extended warranty denied on his cube van duramax because he didn't change the oil every THREE months, they said the miles only matter if they come first. Since it is a business vehicle it was serviced at a certified shop that keep accurate records. Now that sucks doen't it! I tend to change my oil by the book which is THREE MONTHS or 7500 miles on schedule B which if you drive the truck like everyone else applies...2 bits?
Old 02-22-2005 | 01:55 PM
  #59
92DIESEL's Avatar
I havent changed mine for the last 15,000! I have changed the filter though. I have what you call a self purging engine- about 1 GALLON every fill up or 500+ miles. Rear seal is leaking bad.
Old 02-23-2005 | 02:11 AM
  #60
nickleinonen's Avatar
Originally posted by GO 4LO
Twice a year. 5w40 in October or so, 15w40 around April. About every 7000 or 8000 miles.
i do the 2x per year deal like above members... my truck is coming up on 16 months old and just about to roll over 20,000km [+10% speedo/odo error from tires] my truck is a daily commuter
Blessed
10-31-2022 04:27 PM
Crallscars
22
09-10-2011 01:18 PM
keith1992
12-11-2008 06:11 PM
coobie
13
03-16-2004 06:55 AM
93w250
12-31-2002 08:50 PM
Quick Reply: How often do you change oil?
