How much Torque can the CENTER of 12.25" clutches handle ??
1) How much can the center section of 12.25" clutches handle BEFORE they twist apart ??
2) Also, I've "heard" that ALL clutch manufacturers pretty much use the SAME 12.25" clutch frame (metal stamped part) and then insert their own pads (kelvar, ceramic, organic).
What's the scoop on this ??
Just how much TORQUE can the 12.25" HUBs take without breaking.
Are you saying the hub in your NEW clutch is beefier than the previous clutch ??? What brands were BOTH of them ?
My truck has 216k on it and the disc just ripped out this week. Took the pressure plate, pilot bearing and input shaft with it. It 's still in the shop waiting for parts.
I only have a Smarty and drive very easy and don't tow heavy anymore.
old one
http://i289.photobucket.com/albums/l...s/DSCF5591.jpg
new one is just like that, and no i did not pay that much
http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWD1V
Where you towing something heavy when it tore out ??
towing heavy and with about 400hp i would have the center ripped out along with the gears inside on both shafts breaking on a nv4500 tranny. dont know how much torque i had
Just kinda cracked it.
It's a 2wd so no sled pulling, and I have never had a trailer behind it. Runs around empty most of the time too. Broke about 14 months after it was installed, the truck never made more than 800 ft-lbs during that time.
I am very gentle with the power, I apply power smoothly and never apply power until the clutch is engaged. You can see the facing looks almost new. This was a 12" Con-O.
I have a valair 12.25 HD center section feramic clutch and its not had a easy life so far and it is holding up quite well. I have hooked the sled twice with it. I pull a 28 foot camper, I pull my friends 21' dovetail tralior. about 10 to 14k behind me loaded. and I screw around alot. and it hasn't slipped or done anything funky yet. I am happy.
my friends 4x4 has a valair 12.25 ceramic/kevlar and its a good clutch fully loaded with a pallet of concrete and a 20ft goosneck with a bobcat 864 on it even in fith gear up hill this thing will not slip and nothing bad has happened his 5th gear nut is upgraded as well only thing it has slight noise while idel in nutrel but was told this is normal on a cltuch with ceramic his is running a 0 plate full forward as well as the star wheel ff ddp 90hp injecters 14cm2 exhaust housing and all is good
Mechanos
13
11-01-2016 04:27 PM
PEAKSTRYDE
10-11-2007 04:20 PM
AK RAM
01-15-2004 04:48 AM
biglar
02-02-2003 05:26 PM
