How a diesel used to start....
Dad was an IHC man so I grew up with an F-20 an M and a Super C. I didn't know anything about JDs and I always wondered why they had two stacks! That JD R looks like a hefty tractor for those days. I wonder if it origonally had rubber or if it was converted from iron wheels. Craig
I think the second stack (the green one) is actually an air inlet or air cleaner stack, not actually used with the pony motor.
You're right, a 35 hp tractor then wasn't anything like a 35 hp tractor (or even an 85 hp tractor) is these days.
I have a 1916 Fairbanks-Morse 3HP engine that's designed to run on kerosene. Nomenclature refers to it as an "oil engine". You put about 1/2 cup of gas in the mixer bowl (like a carburetor) and start it up. After a minute or so warmup, you switch over to kerosene and then it would run all day at about 400 RPM.
At least that's what it did 50 years ago when it had more compression.
Now I doubt it would run on kero. but it still fires up on gas.
Dan
Dan
Some of my older relatives (I'm 66) refer to the fuel used by these old engines as "stove top". Nearly every farm had kerosene for lamps, etc., even if they didn't have a car or tractor that used gasoline.
During WWII, a lot of tractors were switched back to iron wheels because rubber tires were virtually impossible to buy. And because of gas rationing, "stove top" occasionally found it's way into car fuel tanks.
Dan
Dan
92smokin blacky
05-17-2011 06:50 PM
hitcb1789
05-25-2010 09:10 AM
CoolumConst
10-11-2008 10:00 PM
Common
03-31-2007 10:43 PM
