Here`s a neat product
Your thought is for use with the block heater? If so, it's close but would need a probe to read the block temp. I guess you could always use it to run a space heater in the cab of the truck, lol.
I have had a similar unit in the insulated box that hangs on the shop wall and houses the pressure tank/switch for the well-pump, which resides at the bottom of the well, for a number of years.
The one I have has two outlets, controlled by the one thermostat.
I have a heat-lamp, hanging inside the box, plugged into one side, and a drop-light, hanging outside the box, where I can see it, plugged into the other side; when the temperature gets cold enough, the thermostat turns on the heat-lamp, to keep the water from freezing, and the drop-light, so that I can see that the heat-lamp should be on; thus, if I see the drop-light is ON, and the heat-lamp is not ON, then I better check the bulb.
here is another option with severel temp options. http://www.thermocube.com/ I use them in the pump house in tenn.
windy
windy
I like the Thermocube better where you can buy models that actually are needed to preheat your truck. I don't care to plug in my block heater at 38deg.
I usually plug it in at less than 20deg and leave it on all night.
Here in MN after November there isn't a day where temps go over 50deg.... ...until March
Also
why would you need to "read" the block temp ? When it's cold outside it's cold everywhere regardless of your block temp.
Also
stock03
04-22-2011 09:52 PM
Totallyrad
06-13-2009 02:14 PM
