help me identify this turbo
its a holset said to have came off dodge 5.9 cummins. it is a hx35w, assembly.#is 3538881. thats all the info i have, it looks "clocked" different than what i need , or can it be reclocked. i mean the compressor part has the outlet at top of the assembly when installed. thanks
Yes, you can reclock the compressor by compressing the snap ring that holds the compressor housing to the center section. This is easiest with the turbo bolted to the manifold. If the exhaust side is not lined up right, you need to loosen up the 4 bolts that clamp it to the center. Getting it to move will require a large hammer, this should be done off the truck.
cruiserjg
09-09-2010 01:03 PM
nobody
14
08-21-2006 06:20 PM
stillsmokin
01-08-2006 10:18 PM
