Evans Waterless Antifreeze/Coolant Question
Is anybody here running Evans or any other waterless coolant ? Did you switch to the 203* Tstat and no pressure cap ? I was reading on a Ford site how to completely drain the block of the old coolant. Does the Cummins block have any screw out drain plugs on the block to completly empty it or are they just some kind of freeze plugs ? Where are they located on the block ?
Well FWIW I just talked with a tech at Evans. For the Cummins they reccomend the stock thermostat and radiator cap. And draining all the water out of the block is a PITA but they have some solutions to help purge all the water out.
dieselfan
0
11-01-2006 08:20 PM
