duramax story
duramax story
my old man went back to tennesse this week and he got to barstow calif. and he burnt up the injector wiring harness luckely they dealership got him going again and is on the road. i was giving him a ration of crap b/c it was the second time it has done it to him. ole' faithfull cummins wouldnt do that now would it. i told him he needs to carry and extra set of injector wires with him like and old car car carries an extra set of points.
sounds like the idiot dealer needs to actually read the TSB.
It didnt "burn up the injector harness" so to speak. There is a small area where the passenger side bank injector wires are wire-tied to the alternator bracket. The bracket has kind of a sharp edge, so it can sometimes wear thru and cause problems. How to fix this problem? Take 5 minutes and put some heater hose around the harness in that small area so it protects the harness from chaffing.
The truck will still drive with that wiring harness chaffed thru, just in limp mode.
small wiring issues can happen to ANY truck. Snip one tiny wire on a CR cummins and you will have the same exact problems.
see the picture below for where the harness rubs
Helped pull a 6.0, but just like a D-Max it looked intimidating but it actually wasn't that bad. A body lift or just lifting the body a few inches for the engine removal helps alot reguardless of the brand. (yes even a dodge) If you've ever seen someone who works on a D-Max on a regular basis they can have the engine on the ground in no time, it's quite impressive.
I shouldn't dignify this with a reply, but it sounds like a simple probelm with a simple fix, that was brought to dealer attention with a TSB. Hardly earth shattering news or smoking gun for a poor design. Given a choice, I would drive a Cummins every time, since I am familiar with them. I wouldn't be afraid to drive a Duramax, since most I have had contact with run really well and GM seems to stand behind them. Other than a 7.3 (and even that isn't desired), I would not drive a Ford PowerStroke of my own, and the owner of the truck I am driving better have triple-A.
DURA, ever work on the 4500 Chevys?... the dealer techs have "H" working on them. And WHY oh WHY did they put that fuel filter base in such an impossible spot on the 4500's???... That was just stupid!. When I take mine in to the dealership for a PM, they(the techhs) beg me not to order a fuel filter change.. I've never seen the 2500/3500 engine bay, I've heard the filter base is mounted in a more accessable area.?????
Many have said that they can change it from the top, without removing the battery, but I can't. So I remove the wheel well liner to change it. The job from start to finish takes 8-10 minutes. Which isn't to bad! But it could be better. As my secondary fuel filter is where the extra Alternator would be, and I can change it in 2 minutes. (Plus bleeding the line on both filters of course!)
Change the fuel filter like I used to on my old Corvette. I put a door in each plastic wheel well liner fastened in with DZUS type fasteners. Just take door off, reach in and take filter out! Makes it real nice to get to either side of the engine in a snap. Just try changing a plug or injector on a rear cylinder in a Corvette!!
