Diesel Injection System Cleaning
Old 06-29-2006 | 02:12 PM
BigBlue's Avatar
Originally Posted by Oilguy
Hey Blue... Who is offering the service? Local?
Oilguy
It's a guy off of south college past pickups plus. I can't find his number and I don't remember the name. I'll drive down there and see if I can remember it.
Old 06-29-2006 | 11:26 PM
Ph4tty's Avatar
Originally Posted by Geico266
Add a can of Sea Foam every oil change. You are good to go, and it is only $5.00.
You beat me to it =\ A can of seafoam will treat 33 gallons of fuel. One or two tanks should make a good difference. It can be added to the oil, but that should be like at idle just before an oil change cuz once it starts removing sludge you want to get that crap out. Its a powerful detergent and upper end lubricant when used in the fuel. It'd definately be worth the $10 investment for a couple of cans before spending a few hundred on a shop cleaning.
Old 06-29-2006 | 11:57 PM
BigBlue's Avatar
Well according to the Sea Foam can, one can treats 25 gallons so I went ahead and put 1 1/2 cans in. I've got a full tank so it should be diluted enough. Before my next oil change I plan on dumping it in the oil. With 103k miles and with over half of those very smokey, I figure the engine could use a good cleaning.
Old 06-30-2006 | 11:05 AM
Spooler's Avatar
If it is a BG product it will be a 2 or 3 part kit. One part that is sprayed in the intake, one part that is added to a tank of fuel, and the third part that is run through the fuel system which runs the truck. If it is anything like their gas stuff it will be awesome. Good MPG increase when done correctly. I have ran it many times on Gas engines. On my gas vehicles I just run the can of cleaner in the tank every 10,000 miles and clean the throttle body. Works better than anything you can buy off the shelf at Wall Fart or AutoJonesin.
Old 07-01-2006 | 12:27 AM
DeweyND's Avatar
Sea Foam
When I change the fuel filter, I fill the cannister up with Sea Foam, instead of "filling" it with fuel via the lift pump. I'll also dump what little is left, along with a full can, into the fuel tank. Also, mix it in my 2.5 gallon gas jug that I have for the lawn mower and snow blower. Also use it in the gas tank of my older Goldwing cycle.
If anybody dumps it into the carb/intake system to clean out the carbon buildup in the upper end, pay attention to the "caution" on the can......the exhaust really SMELLS BAAAADDDD!!!! Do not do this inside an enclosed space . I did a grain truck engine years ago that I had (did it outside), and even in the open air, the smell was terrible.
Dewey
Old 07-02-2006 | 12:07 PM
Ace's Avatar
Ace
This sounds like the high margin-type "service" shops and stealerships love to sell. Costs them next to nothing to collect your 150 bucks and what do they care what it may or may not do to the vehicle over the long run.
A good running engine maintained that way with proper fuel adds and other routine maintenance should never need this type service.
Old 07-02-2006 | 12:26 PM
BigBlue's Avatar
Well this shop has a pretty good reputation around here and after talking with the guy I feel very confident in that he's not just trying to make a quick buck but that he's actually very confident that this machine does work. Is it worth $150? Probably not but who knows. I may try it one day if I feel rich.
Old 07-02-2006 | 01:51 PM
Ph4tty's Avatar
Dewey
Are you talking about the seafoam deep-creep? Ya that will make a gasser blow black smoke when you start her back up.
I use the regular seafoam as a fuel stabilizer plus I use in the bike and lawnmower.
Old 07-02-2006 | 03:18 PM
DeweyND's Avatar
Ph4tty,
Nope, just the "regular" SeaFoam. Never heard of Deep Creep?
Dewey
Old 07-02-2006 | 10:27 PM
hillfolker's Avatar
im a vw dude,and sometimes we use this stuff made by "lubro-moly"
called "diesel purge"
what we do is disconnect the inlet +outlet(fuel)
and basically rig a fuel line setup so you can run it out of the can of purge,its like a qt,and my car will run off it for 10-20 mins just sitting there,and revving it up once in a while
since you guys have those lift pumps and all that,id put this stuff,or 2 cans of it cut in half with diesel,and run it out of a small gas can
since that stuff is cheaper,id use it first,before some possible several hundred dollar service,ithink its around 10 bux?a can,look around for it
lubro-moly diesel purge
Old 07-04-2006 | 12:59 PM
hillfolker's Avatar
wanna smell a nastysmell??at work we screw with each other,spray some gunk brake cleener down the intake of a running diesel,the smell that comes out the exhaust will burn your eyes+send ya runnin,lol
Old 08-20-2006 | 01:57 AM
Teddy Bear's Avatar
What kind of work do you do?
Old 08-20-2006 | 02:29 AM
BigBlue's Avatar
For any of yall in the college station/bryan area, the place is called hill's automotive (hope I don't step on any toes here, if so then let me know). I'm about a needle width away from doing it. I've run used oil, 2 stroke oil, lucas, sea foam, diesel clean, STP, all sorts of stuff through my truck so I figured that maybe a good cleaning will help.
Old 08-20-2006 | 10:12 PM
Oilguy's Avatar
Hey Blue...
I have never heard anything bad about that company... and believe me... If there is anything bad about a mechanic shop in town... I WILL hear about it! It is the nature of my business (quick lube)... everyone feels the need to tell me the horror stories.
OG
#1sidewinder
11-03-2014 01:16 PM
tommurray
02-23-2014 10:38 AM
capt.Ron
07-26-2010 09:17 PM
steelblitzkrieg
04-12-2009 10:41 AM
rjm022
02-03-2007 09:35 PM
Quick Reply: Diesel Injection System Cleaning
