Diesel-electric ram hybrid going into production.
This 20 kW generator is enough to power four homes or a big job site, it's attached to the bed of a Dodge Ram 2500.
http://a332.g.akamai.net/f/332/936/1...pecial.500.jpg
Thats a 2nd gen. in the picture. Is it the same for the 3rd gen. trucks? IT would be VERY nice to be able to run a welder off of your truck. Very nice for farmers who want to go out in the field and make repairs instead of having to buy a motor powered welder.
Eric
Eric
Originally posted by Tartarus
Max torque at zero RPM . . . . fantastic trick. Then the engine/motor doesn't have to be running to get anywhere? Theoretically-infinite mpg? 99 on the overhead console? Or is that max torque at one RPM?
If max torque at one RPM (600 lbs.), towing 11K lbs., then new clutch? Don't think the stock units would handle it. Weak clutch problems solved? Or would we all have to go with (gasp) an automatic?
The definition of torque is a force that produces or tends to produce rotation or torsion also called the moment of force. No RPM is required to produce torque. Horsepower, however, does require the action of rotation or other linear motion.
Gary
The military version is called the COMBATT COMercially BAsed Tactical Truck. It's more than a hybrid electric....some cool suspension mods. It was a competition that started out with all of the "Big 3" competing. GM was weeded out early on. It was Dodge vs. Ford, but looks like the Army will be buying both.
The military plans to lease them from DC for 3-4 years which means DC will be reselling in '07 or so. I'm sure that fire departments and forestry departments will be buying them up then.
I did a Google search for Dodge COMBATT:
http://www.trucktrend.com/roadtests/.../163_0304_com/
http://waw.wardsauto.com/ar/auto_dodge_ford_combatt/
http://www.rockcrawler.com/features/...C_ram_army.asp
http://dodgeram.org/rides/combat_ram/military_ram.html
http://www.tacom.army.mil/tardec/nac/combatt.htm
http://www.tallahassee.com/mld/brade...ve/7456412.htm
Originally posted by Richard1234
Well then, steam has max torque at zero rpm. I guess electrec motors would be the same, huh?
sled4fun
04-29-2007 11:29 PM
mrb321us
07-06-2004 07:21 PM
RedRocket
05-12-2004 02:06 PM
