deutz 511 engine
deutz 511 engine
I have a deutz fil 511 I need a manual on the engine or a way to download the manual. The engine has problems with the governor because when I start the engine it will run wide open. The unit was not run for 18 months and now is giving problems. Thanks for any help
Dad has a deutz something or other in an IR compressor, had the same issue, as well as surging. found out that there were about five screws loose on the case of the injection pump causing it to leak air and such. tightened them all up and it works fine now.
if tightening the hardware does not fix it try running a 50-50 mix of dextron atf and #2 diesel this will usually get the governor unstuck from the condensate caused rust
fuel leak
I have a leak around the bottom of the injector pump where is comes out of the cover. Can that cause the no governor problems. I will to fix the problem as well. I dont know if it is sealed by o rings or washers? The 50 / 50 mix of fuel and atf is added to the fuel? I need to buy a manual or I wish i could down load a manual. Thanks for all help
I have several deutz/kohler gensets in my radio sites for standby power.
Rick Aafedt at Pacific Detroit Diesel-Allison in Spokane has been a big help to me in obtaining the correct parts, he can probably get you a manual.
509-535-3663
509-535-0542, ext 109
800-882-3860
raafedt@pacificdda.com
Hope that helps!
509-535-3663
800-882-3860
Hope that helps!
509-535-3663
800-882-3860
Hope that helps!
509-535-3663
800-882-3860
Hope that helps!
1workin...
I don't know about this site too much, but this might be worth a look:
http://www.alibris.com/booksearch.de..._-nonisbn-_-na
I would not ordinarily post something for sale,I just googled "deutz 511 engine manual" and this and several more items came up.
Good luck...
Good luck...
53 willys
08-04-2007 10:55 AM
