Custom Gear Shift?
Custom Gear Shift?
Does Anyone Have A Custom Gear Shift In Their Truck? If So Do U Know Where I Can Get One And How Much Am I Looking At...i Want The Whole Shifter. I Would Like To Extend It Maybe Another 12-14 Inches....if Any One Has It Do U Like It Or Dislike It ? Did It Cause You Any Problems? Thanks For The Feedback
lol, I was actually thinking about doing the same thing...kinda like those big shifter handles they have in the custom big rigs...would be way awesome to grab gears from chin level!!! Let me know if you find one, I can find em anywhere...
Sounds easy the previous owner must have glued mine in because I had to break it to get it out.
I bought a Hurst classic musclecar **** from Summit with the correct shift pattern. It has a brass insert that did not fit the 10 mm thread on the shift arm but I was able to extract the brass insert and turn a replacement with the right thread. One problem with the shift arm is it tapers down to the 10 mm thread and looks a little funky. To fix this I turned a stainless steel sleeve to cover the taper.
