Custom fuel mapping marine application ?
Hello
Anyone have any experiance or contacts for someone able to tune a marine 5.9 24valve ECM they are essentially the same as the truck ECM with different connectors , no obd2 port, it has a 9pin deutz style connection, im installing a twin turbo set-up on a pair of marine 2009 5.9's looking for an outside influance to help with the electronics/tuner any and all ideas welcome
Thanks
WS
Thanks
WS
I posted comments on your other thread. Theres' more info here so I'll add what I can. When adding a programmer like Quadzilla the OBD(under dash plug) plug isn't used. you connect to the data link, map sensor and pump wire if tapped. Since you have twins you can also upgrade the injectors to add more fuel. wooops, I see it's an 09 probably has a cp3 pump which I'm not as familiar with. keep searching on here for 3rd gen upgrades and you'll find more answers to your questions.
banana
07-16-2010 03:58 PM
Sarge1124
11-12-2002 11:02 AM
