Cummins vs. Powerstroke Connecting Rods
#32
#34
You got to remember that the Cummins is rated as a 'Medium Duty Diesel' while the Powerjoke and Diapermax ar 'Light Duty' diesels. That's why their 'puters won't let them make any torque until they're a ways above 2 grand. They are a throw away outfit from the get go. That baby Alison in the GM is a joke also! They start gettin' hot and the computer de-rates the engine to save the tranny while you end up sitting on the side of Monarch or Red Mountain Pass with your face hangin' out and the Powerjokes are just as bad when they are loaded and pulling grade. If they pulled as hard as a Cummins down low in the Rs they would both shell those wimpy rods right out the pan. I've seen too many of them sitting on the shoulder to ever consider giving them anything but the high sign when I blow by them.....Man, you boys really got me to going. I'm going to bed. C-ya!
#36
http://www.internationaldelivers.com...t365detail.asp
#41
I-6 is better for stump pulling torque.
I think you might be confusing rod length with stroke.....the longer stroke does mean the potential for higher torque output but it isn't the be all end all as far as torque generation is concerned as some people may have you believe. Rod ratio (the length of the rod versus the stroke of the crank) is also a key factor in torque generation. The Cummins rod has to be longer than the others just to maintain even the same rod ratio as other engines with less stroke. And it has to be beefier than the V8 rods since it has only six rods to transmit comparable forces that other engines have eight rods to transmit.
There are advantages and disadvantages to high and low rod ratios.....some of the more important factors that are considered are piston speed (the longer the rod, the lower the speed - the lower the piston speed, the worse it will perform at lower rpm), time at TDC (dwell - the higher the dwell, the more time for flame travel and complete combustion - more important at higher rpm), and piston side loading in the cylinders (shorter rods will side load the pistons in the cylinders more than longer rods since the shorter rods spend more time operating at greater angles - the higher the force the piston has to endure, the more pronounced the side load).
The engine designers must select a rod ratio that is a balance (compromise) of these factors that best suit the intended application.
#42
That’s one of the best and most understandable posts I think I have ever read!
Einstein would be proud! Thanks very much for you time, and thanks for sharing your talents and knowledge with us. I find your way of describing things excellent.
Best Regards,
Tom D
Best Regards,
Tom D
#43
Thanks for the thoughtful post.
#44
Seconded. Outstanding post.
