Cummins vs. Powerstroke Connecting Rods
Old 11-29-2006, 08:51 PM
wcbcruzer's Avatar
The Cummins also has 200 lbs. more steel over the DMax.
Old 11-29-2006, 08:57 PM
Muted User
NukleusX's Avatar
Originally Posted by P.J
Bigger is better.
Cant say I have always heard this from the ladies P.J.
Old 11-29-2006, 11:07 PM
XLR8R's Avatar
Even though the Cummins has two fewer holes, the rod's massive construction looks like quite a bit more than the 33% difference one would expect from the different cylinder configurations.
Makes ya feel a lot safer abusing it!
Old 11-29-2006, 11:13 PM
Muted User
NukleusX's Avatar
Hahahahaha Could not agree more. I have fears on my dad's Powerjoke he put a banks kit on at less than 2k miles that something will go wrong, that is directly or closely related to the banks kit.
As for my truck, I fear nothing will go wrong, if I do anything to it.
Though I just noticed just the other day I have a FUEL leak from ON/IN around the fuel filter. Didnt think it is time to change the bugger or what, though come a few spare minutes time that thing and the gasket will be changed out. Hopefully ir is nothing more than just that.
Old 11-29-2006, 11:22 PM
XLR8R's Avatar
Sometimes the fuel heater plug leaks.
Old 11-30-2006, 06:54 AM
superf350's Avatar
Is it just me or does the PSD rod look wider? Isn't girth what you really want?
Old 11-30-2006, 09:55 AM
XLR8R's Avatar
Longer and thicker is stronger.
Old 11-30-2006, 11:55 AM
superf350's Avatar
It's longer but it don't look thicker. I'd think shorter/thicker would be stronger than longer/thinner.
Old 11-30-2006, 01:06 PM
CTD NUT's Avatar
Guys,
There are good and bad attributes to both the long and short rods! There simply is no such thing as one rod that is better than the others.....differing applications will dictate the optimum design.
One thing to remember about the shorter rod is that it will have to be beefier than the longer rod to hold the same loads since it is always operating at greater angles than the longer rods and side loading the pistons more. Shorter rods will need to be stronger at the connecting points and longer rods will need stronger beams if you must generalize!
Old 11-30-2006, 01:56 PM
XLR8R's Avatar
What size rod do you guys prefer?
Old 11-30-2006, 02:25 PM
XLR8R's Avatar
Well, I think the Cummins rod certainly looks much stronger.
Old 11-30-2006, 02:26 PM
dodgezilla04's Avatar
careful............ hate to get this shutdown. this COULD be informative.
Old 11-30-2006, 02:29 PM
XLR8R's Avatar
I just think there's such an obvious difference in the amount of steel used to make the rods that I don't see how the Cummins rod couldn't be stronger and more durable.
Old 11-30-2006, 02:30 PM
XLR8R's Avatar
Yeah - nobody take this to the gutter!
Old 11-30-2006, 02:34 PM
lovinCTD59's Avatar
Lets not forget the 2001+ 7.3 and 6.0 power stroke have powder metal rods that snap with anything more than a chip (they shoulda stuck with the forged rods)
Quick Reply: Cummins vs. Powerstroke Connecting Rods
