View Poll Results: cummins or hemi ?
cummins 5.9 12 valve
41
87.23%
hemi 5.7
12.77%
Voters: 47. You may not vote on this poll
Cummins in a off road buggy ???
Ight been looking into building a tube buggy mabe with somthin like a sniper or poison spider frame but my qustion is should i drop a 12 valve 5.9 cummins ?
my ponders are when i role over is that gona hert the cummins ? steep inclines gona hert the motor ? hard hits on the trails ?
bad stuf i have is its heavy , large exaust , and its pretty big .
good stuff , i have only seen a few with a cummins , lots of power , would sound great .
so what are yaws opition on this matter any pros and cons ? any one done did this thats on here ?
or should i drop a hemi ? wich will prob cost much more + it will have a comp. wich im not a fan of.
thanks , nathan
thanks , nathan
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
I think the Cummins would be killer, but it is big and heavy. Maybe the Hemi would be a better choice for a rock buggy. But then maybe not........
It's a 5.9 with 2 cyl cut off. Used in lighter equipment like backhoes and some skeed steers. Use your imagination . I think they make 99+ horse power N/A.... Correct me if i'm wrong.
Rockwells have a 6.72 gear ratio and 4bt's can be turned up pretty good. Not sure how much, but with that ratio and a torquey little 4 banger I think it would be just right.
Its not HP your after, its Tq...With Rockwells your looking at like a 7.62 ratio, plenty to crawl with. You'll also probably run something like an Atlas II, or maybe a Stak 4x4 T-Case, so you'll have plenty of gearing. Also, keep in mind, more than a few 4BT's came with P-Pumps, so they can be tweaked easily, and can make a lot of power.
Its also a lot lighter and compact, so fitting in the truck will be a lot easier, and you'll keep your center of gravity lower...Big plusses in a rock buggy.
I'd go with the Cummins. I was watching a rock crawling video and there was a guy that had a Jeep CJ with a 5.9 Cummins and it and a hood stack and it just about idled over the rocks. A 4BT would be cool too. I've seen a few around where I live and they are pretty cool
Well...remember with a diesel you have keystone rings, so as long as the motor is running you won't get hardly any oil in the cylinder, unlike a gasser. There's one plus, the biggest downfall I can see is that your turbo's oil return line could fill with oil, possibly contaminating it with dirty oil, but I don't think its a big deal. No Carb to spill fuel from, also makes it a lot safer.
I can't see any reason why it would be worse than a gasser, but a few reasons it'll be better. I'm sure a few other guys will chime in.
im not worried about burning the oil . depends on how much oil passes thru the rings . i dont want it to be to the point that when i turn the motor over that is has so much oil in the cyl that it compresses and cause damage
well im pretty set to go with a 4 bt cummins found a few on ebay .
any one have any leads for a 4 bt ?
