Cummins engines getting bigger?
Old 04-10-2006 | 05:07 PM
Equipment man's Avatar
Went out and worked on a Skytrack today. It had a B series cummins 4 cylinder (4BT) with a displacement of 4.7 litres!
From what I have found out so far it looke like the 3.9 is gone and has been replaced with a 4.7
I'm wondering if the 5.9l 6 cylinder is next.
at .2l/ cylinder increase, if we extrapolated that to the 6 cyl, that would mean we would have a 7.1l 6BT. One can only hope.
Anyone out there know something else about this? I'm definitely all ears and excited.
Old 04-10-2006 | 05:09 PM
The 6.7 liter is supposed to be introduced mid '07 MY.
Old 04-10-2006 | 05:12 PM
smokindog's Avatar
Not quite 7.1L, but close. Read this !
Old 04-10-2006 | 05:38 PM
Well, i wasn't far off. I'm kinda thinking i want to get my hands on the 4.7 4BT. The one I looked at was made for varying RPM's up to 2600 redline. Unfortunately it only made 110 HP. But with what looked to be a baby VP44(2 lines missing) and electronics, it may accept an edge box
Thanks for the link, now i really have something to be excited about.
Old 04-10-2006 | 06:04 PM
signature600's Avatar
Actually, I think it's a 4.5L. At least the ones we used in the AGCO tractors were. The Case-IH tractors were the same (4.5L), but electronicly controlled
Chris
Old 04-10-2006 | 08:21 PM
JKM's Avatar
JKM
Case still has the 4 cyl in the MXU series , there is a common rail version , and a lower hp mechanical injection version, the bigger MXU's use the 6.7 , also depending on model some have common rail , some have mechanical injection.
Old 04-11-2006 | 03:39 PM
you are right, it is a 4.5l
The data tag reads...
DOM 04/oct/05 Cust Spec 8262162
275/4.5 Model ?SB4.5
CPL 8401 Serial 30208737
110 HP @ 2500
The ? after the model # is because that letter was illegible.
This was not a common rail engine (wish it was), Instead it was a VP-electronic- pumped engine with a mechanical fuel pump. Kinda an odd configuration but it seems to work well.
Old 04-11-2006 | 06:33 PM
JKM's Avatar
JKM
that ? mark you have in there should be a Q , it is the QSB series , kinda like the ISB (24 valve) in the dodges.
Old 04-14-2006 | 03:34 PM
Ray Roton's Avatar
http://www.tdr1.com/06ntea/
andyboland
21
01-08-2020 11:32 PM
cbx
05-18-2009 07:23 PM
R & A Equipment
02-26-2007 11:27 PM
Dieselhead
03-27-2003 11:24 AM
Quick Reply: Cummins engines getting bigger?
