Cummins Coolant Service Bulletin
Old 11-19-2003, 10:22 PM
RCW
RCW's Avatar
I have been getting a bunch of questions about the cavitation issue and coolant maintenance. This Service Bulletin has been in effect for over a year. Our baby Cummins engines need to be watched for nitrite and molybdate levels, just like the real trucks. Obviously, most Dodges do not have the coolant filters, no room for them, but all my tractors that use the B and C series engines do.
If in doubt check with Cummins. I did, and Cummins NW told me to follow this service bulletin (this is only the short summary).
Service Bulletin Number 3666132-02
Date 01-NOV-2002
Design Application Market Application All
Service Bulletin
Cummins Coolant Requirements and Maintenance
This service bulletin supersedes prior service bulletins concerning Cummins Inc. coolant requirements and maintenance; replace those service bulletins with this one.
This service bulletin outlines the proper application and maintenance of coolant for all Cummins engines, including gaseous fueled engines. It also updates and simplifies Cummins recommendations and guidelines for the end user.
Summary of Recommendations
Cummins Inc. cooling system general recommendations are listed below. These recommendations apply to both Standard Service Intervals and Extended Service Intervals. Refer to Section 2 or 3 for complete instructions.
1) Fill up and top off cooling systems with a fully formulated antifreeze/coolant meeting CES 14603.
2) Replace the coolant filter(s) at every recommended coolant filter change interval.
3) Add liquid Extender/SCA at each filter change as necessary.
4) Test coolant at least twice per year for liner-pitting protection (nitrite and molybdate levels). Test coolant for replacement limits every 240,000 km [150,000 mi ], 4000 hours, or once per year, whichever occurs first. Replace coolant only if replacement limits have been exceeded.
Old 11-20-2003, 07:11 AM
Holsteinman's Avatar
Re:Cummins Coolant Service Bulletin
That's all nice, but our engines do not have liners.
Old 11-20-2003, 06:51 PM
spots's Avatar
Still subject to cavitation tho. Just like the 7.3.
Old 11-24-2003, 10:36 AM
thumper 549's Avatar
to make a long story short cavitation dose not care if the cyl is a linner or cast to the block..Look at a ford 6.9 for instance and trust me its not cause it is a ford its steel and that is all that matters.
Old 11-24-2003, 10:40 AM
JKE
JKE's Avatar
anyone got the hard facts on where to get the additives and test kit? How much? etc. etc....One test will tell you if Cummins/dealer put in the additives to begin with.
John
Old 11-24-2003, 11:25 AM
dodgeman01's Avatar
I guess that means my 94 dodge with 145k miles needs to have its coolant changed
DM01
Old 11-24-2003, 11:28 AM
JKE
JKE's Avatar
You got that right!...even without cavitation, that is too long...
John
Old 11-24-2003, 12:12 PM
dodgeman01's Avatar
Just relized my 93 has 180k on the factory coolant
DM01
Old 11-24-2003, 12:56 PM
JKE
JKE's Avatar
cooling system must be far better than a gasser chevy ....bought a 3 year old chevy with 50,000 on it and never had the coolant changed...10,000 miles later, water pump and freeze plugs were leaking. (holes rusted through the freeze plugs) What a mistake that truck was :-X
Old 11-24-2003, 03:33 PM
I thought Cummins stance on this is we do not have to use additive in the 5.9, but would not hurt anything if we did.
Old 11-24-2003, 05:17 PM
Monty's Avatar
Thumper is right. Cavitation can occur in an engine that is not linered. Cavitation occurs when the cylinder causes a vibration and actually expands and contracts. The expanding and contracting causes air pockets between the liner, or block if non sleeved and the coolant. During this process the vibration causes the coolant to come crashing into the air pocket and cause pitting on the liner. Nitrite is essential for this because it actually coats the liner to help prevent the imploding getting to bare metal.
I wouldnt worry to much about the additives or coolant filters. Just use an approved coolant and change once per year. Unless you are running an extended life coolant. I am running the Fleetguard ESComplete (blue in color), it is good for 600k but you need to check the acidity level ever so often.
Old 11-24-2003, 07:32 PM
spots's Avatar
Or (dare I say it) go to a Ford dealer and get the additive for their diesels. Two bottles does a truck (I think) and it is cheap.
Old 11-24-2003, 09:36 PM
bulabula's Avatar
[quote author=spots link=board=8;threadid=22633;start=0#msg213738 date=1069723955]
Or (dare I say it) go to a Ford dealer and get the additive for their diesels. Two bottles does a truck (I think) and it is cheap.[/quote]Boy, I wouldn't put any Ford stuff in it; it might get the romps, or worse - the dreaded Dead Pedal!
Old 11-25-2003, 05:14 AM
spots's Avatar
[quote author=bulabula link=board=8;threadid=22633;start=0#msg213826 date=1069731410]
[/quote]
is the romps anything like the trotts??
Old 11-25-2003, 06:30 AM
JKE
JKE's Avatar
You get that from eatin' chinese 4 days straight right? ;D
Nitride - now that is an amazing operation/process. we have one here in the plant. We use it for our product, but also on other things that we want to hold up a long time...it works first rate.
John
Quick Reply: Cummins Coolant Service Bulletin
