Boost question
Old 10-19-2005 | 06:08 AM
Tengu's Avatar
Boost question
I was under the impression that my 2000 would only produce 21 PSI before it starts to defuel. Last night I was passing someone on a hill (A PSD) and I thought I saw it go to about 25 PSI. I payed attention on the next hill and I saw it again, Sustained. What gives?
Old 10-19-2005 | 06:16 AM
TAS05CTD610's Avatar
Boost
Most Cummins go higher than that. Anything over 50 and you should have the head ringed to keep it under control with that pressure. i have an 05 and I see 34 when I get on it. Not sure about your year (dad has a 99) but I'm pretty sure it'll get that high. he has a boost elbo and edge ez, so I'm sure that helps. I wouldn't worry about it there, and I don't think it defuels at that boost. Normally they don't fully fuel untill there's boost. I'm not an expert on that year (or my year) But I think that's right.
Old 10-19-2005 | 08:51 AM
Mopar1973man's Avatar
Since I don't see a box or a boost fooler I would say you wastegate is sticking.
Mine has been running up to 20-21 PSI and popping open and failling rapid to about 18-19 sometimes lower for a second. This only happen for me in 2nd gear where I can build boost fast.
Old 10-19-2005 | 09:19 AM
Tengu's Avatar
Is this a problem?
Old 10-19-2005 | 09:41 AM
It should be de-fueling and throwing a error code for that much boost... Stock form they only will go to about 21 PSI then throw a overboost code and start de-fueling.
You might check you map sensor & your wastegate... These are the only two thing I know that control boost pressure and defueling...
Unless one of the guru's have got something else?!?!
goose2w1
07-23-2008 10:49 PM
3500_CTD
14
02-05-2008 08:33 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
GTSDave
07-08-2005 09:06 AM
Quick Reply: Boost question
