Block heater on 2001 FORD?
Old 12-16-2008 | 01:47 PM
Roperteacher's Avatar
I have a friend who can't find the blockheater on an 01 ford Stroker. Do they even have one? I guess their 02 is easy to find just not the 01. Thanks!
Old 12-16-2008 | 02:13 PM
JD730's Avatar
Can't find the plug or can't find where the heater is screwed into?
The plug should be behind the bumper or behind the grill somewhere.
The heater itself is right above the oil filter.
Old 12-16-2008 | 02:25 PM
Thanks for the help!!!
Old 12-16-2008 | 10:12 PM
snoyes's Avatar
Should plug in right by the oil filter as JD730 stated. I'd start looking there and work your way forward as they tie the thing up where it is hard to find sometimes. If he's missing the cord, you should be able to pick one up from the international truck store for cheaper than the Ford dealer.
Old 12-17-2008 | 05:33 AM
Hvytrkmech's Avatar
What they said. The only other thing is that Ford loved to tape them back onto the harness when new. You will have to dig for it. Lay down under the front bumper, then feel for a bundle of wires tucked down at the bottom of the inside of the bumper, you can see the serrated ends of the harness push clips from the back side of the bumper. You will have to push the serrated clips out to get the wiring harness out from inside the bumper so you can work with it. At this point you will find that the block heater cord is taped to a long rigid piece of plastic. I removed this plastic on my Fords so I could reroute the cord for ease of use. It is all self explanatory once you locate it.
If for some reason it does not have a cord you can call Cummins or International to get one also, (Cummins will be the cheapest). The cords are the exact same connection, one may be longer than the other, but that does not matter. A cord cost me appx $10.00 from a Cummins shop
Good luck,
Tim
Old 12-17-2008 | 08:22 AM
bandit408's Avatar
Funny thing Ford started doing in 99 was every diesel engine had the heater element installed and if you were in the south you could pick if you wanted the cord installed otherwise it was never put on. If it is a truck that is meant for the north a block heater was standard. Sometimes you have to do quite a bit of searching along the harness to find the plug so you can pull it through the grill.
wdimig
09-29-2010 07:38 PM
madhat
01-07-2010 03:31 PM
supersonictoys
11-08-2008 09:17 PM
county cowboy
01-27-2008 08:51 PM
Reelay
12-01-2005 06:14 PM
Quick Reply: Block heater on 2001 FORD?
