Best way to machine out the h2 wheels.
Old 12-14-2006, 07:02 PM
Ramdriver15's Avatar
Question Best way to machine out the h2 wheels.
i am picking up a set on sunday. I would like to know what is the easiest way to machine these out on my own. i have no fancy tools to do it except a drill. I went out looking for a hole saw and all i found were 4 in and 4 1/2 in hole saws. I am not going to a machine shop because they want 280 bucks to boire them out.
All help is appreciated.
Thanks
john
Old 12-14-2006, 07:43 PM
TopBanana's Avatar
u can use a hole-saw, there is such a thing as 4 3/4", which is what you'll need. you'll have to make some sort of jig to keep the bit centered in the bore. it will drill pretty easy with a new bit.
if u have any sort of access to a bridgeport you can use it with a boring bit, that's how i did mine.
Old 12-14-2006, 07:50 PM
i have a bridgeport at school, but the teachers are not sure on how to use it to bore the wheels evenly. there is a boring bit in the machine now though, any instructions for using this machine?
Old 12-15-2006, 11:05 AM
Raspy's Avatar
Location: Smith Valley, NV (sometimes Redwood City, CA)
TopBanana,
No you don't have to make a jig to use the holesaw. That's the beauty of it.
On the front of the wheel the hole is already out to 4 3/4" so the saw drops into a recess and is contained and centered perfectly. Only about 1/2 of the hole's depth has to be cut out.
After the cut though, you still have to sand the hole to smooth it up and get the final few thousandths out. A 2" drum sander in a high speed drill works well.
Wetspirit
Old 12-15-2006, 11:25 AM
John Faughn's Avatar
Whats wrong with this picture !!!
I think you need to find a new school , if the teachers do not know how to use the equipment that is there .
Old 12-15-2006, 12:56 PM
Forrest Nearing's Avatar
I think you should find some different wheels (unless that price is with tires)
not a big fan of those wheels
Old 12-15-2006, 01:54 PM
forest they are with tires and the guy said he might go lower too!!! so i mean its worth it and i like the idea of spending 150-200 bucks to buy set of wheels and tires...
id rather go with an aftermarket but im not all that well off seeing im in highschool, working a 15 hour weeks getting paid crap and have to pay for this truck and insurrance still... yuck!
Old 12-16-2006, 05:42 AM
Jim Lane's Avatar
Thanks
john
4 3/4 hole saws are available, Graingers has them, you might also try an Eletrical Whosale Distributor for them like B&K Electric.
http://www.grainger.com/Grainger/wwg/start.shtml
4XJ12
Bi-Metal Hole Saw, Saw Dia 4 3/4 In, M3 High Speed Steel Cutting Edge with Hardened Steel Backer, Max Cutting Depth 1 1/2 In MORSE
AV76 1 Today $42.30 page-1309
4XJ80
Hole Saw, Saw Dia 4 3/4 In, M3 High Speed Steel Cutting Edge with Hardened Steel Backer, Max Cutting Depth 1 1/2 In, Teeth Postive Rake Variable Pitch MORSE
TA76 1 Today $52.35 page-1308
4VV97
Bi Metal Hole Saw Kit, Master Industrial, M3 High Speed Steel Cutting Edge with Hardened Steel Backer, Number of Pieces 25, Max Cutting Depth 1 1/2 In MORSE
AV23M 1 Today $233.00 page-1307
3Y166
Steel Hawg(R) Hole Cutter, Size 4 3/4 In, Max Cutting Depth 2 In, Carbide Tipped With Inside/Outside Multiple Cutting Edge, For Cutting Steel Plate MILWAUKEE
49-57-4750 1 From mfr. w/in 3 bus. days $1,320.00 N/A
6UV33
4-3/4" Hole Saw Deep Cut Bi-Metal DEWALT
D180076 3 From mfr. w/in 5 bus. days $42.70 N/A
Old 12-16-2006, 07:25 AM
adventuris's Avatar
hi ramdriver , did mine on bridgeport , use boring bit or get a adjustable circle cutter thats what i did center wheel in machine under cut need to have tires off use the area thats already cut alittle as a guide . first one toock 30 min to set up after 5 mins a rim .
Old 12-16-2006, 08:26 AM
2500's Avatar
sounds pretty tempting for $150-$200 a set with tires.
do these H2 wheels fit all 3/4 ton CTD's? with hole cut out of course.
what size are they?
Old 12-16-2006, 12:24 PM
CZSteve's Avatar
Not to hi-jack here, but...
Will the H2 wheels w/ their stock tires (315/70/17) fit on a stock 2WD 2500?
Also, it seems that the standard H2 tires are load range D - thoughts?
I'm going to be needing new tires in the near future, mainly a daily driver and a 3500# boat for weekend towing.
Old 12-16-2006, 09:49 PM
well i guess all the worrying about the hubs was for nothing. they are already drilled out. they were on a powerjoke!!! lol
well i guess im buying rubber soon for them and for 200 bucks thee are pretty sweet
Old 12-17-2006, 04:29 AM
PistolWhipt's Avatar
I was kinda wondering about that too .... if you can't dial it in, you might as well not machine it.
Good deal on the wheels ... please post the pics when you get them on !!
PISTOL
Old 12-17-2006, 10:20 AM
yeah, you can't beat that with a bat!!!!!!! sure beats $200 a tire!
Old 12-17-2006, 12:44 PM
Lama's Avatar
There is no way they were on a Powerstroke, those have a different metric bolt pattern, I would double check you center opening is at least 4-3/4".
Quick Reply: Best way to machine out the h2 wheels.
