AmsOil Ea BHAF?
AmsOil Ea BHAF?
Does anyone know if Amsoil has an Ea nanofiber air filter of the same dimensions as the typical WIX or Napa BHAF? Ive checked the web site but its cross reference says that it has been discontinued. Perhaps the site is wrong. Any tips would be great.
Thanks
Thanks
Amsoil Air Filter
I installed an Amsoil EaA 189 air filter in my 2005 truck last May 27th, 2007. It depends on the demand for filters suitable for your year of vehicle, whether or not there will be one available. I queried the Amsoil warehouse about their latest air filters being available for other vehicles such as 2007 335i BMW cars and 1994 Virago 750cc model motorcycles, but they did not have any available because of little or no demand. They also did not have oil filters available. I am strickly an Amsoil user, because of their lubricants superior performance.
Ok. But is it the same size as the paper BHAF? Im not trying to sound like an ignorant broken record but I just wanna make sure. I was getting ready to run out and drop $45 on a napa filter but if I can go Ea Id much rather do that even if it is more expensive.
I placed the Amsoil sticker on top of my air cleaner cover with the date it was installed and the date when it is to be cleaned. A piece of tape is stuck on the cover that says, CLEAN WHEN FILTHY-DO NOT REPLACE written in red ink.
Sealing?
In my 2005 filter enclosure holder the EaA 189's dimensions seemed slightly too large for the openning, but it was carefully and firmly pushed into it and the air box top replaced. It is sealed properly and causing no problems. I previously used Amsoil's sponge rubber and tack oil air filter, but the new Ea filters are more convenient to use and it does a more efficient job of air filtration.
I have no idea why they replaced it with a Moper filter. He did tell me only to use Mopar filters. When I said fleetguard (which is what I used) mads Mopar, he had no response. He also told me I needed to spend $3,700.00 on 6 new injectors. He said I had contaminated fuel. Truck run and idles fine. I also mark the date of filter changes on tape applied under the hood for all to see. They also broke my oil dipstick handle and replaced the fuel filter cap so tihjt I had to remove it with an extention and breaker bar.
Dishonesty is not the best policy in the long run.
Spooler
28
12-26-2009 10:16 AM
MATTIEBOB
22
12-28-2007 10:22 AM
czkid
10-18-2007 07:38 PM
Hoss
16
01-10-2007 11:35 AM
