4BT Performance Injectors
Help!! I'm putting a 4bt into an '85 K20 Suburban, and need some quick help. I'm looking for performance injectors and at least a 4,000 rpm injector pump governor spring set. Anybody know some retailers who sell 4bt parts?
Thanks in advance,
Jason Rawlings
Thanks in advance,
Jason Rawlings
Thats assuming its a VE engine. The p-pump versions are identicle to the 6bt, just with two barrels missing. All the parts still swap. There are some 4bt's with A-pumps and P-3000 pumps that a bit different, so watch out for that.
If you get the 4k spring, get the 60lbs valve springs.
There is only a spring in the "kit". Also, get a bigger turbo (since your 4wd) with your injectors.
A good place to check out is www.4btswaps.com
600 Megawatts
02-11-2008 11:07 AM
JimmieD
16
07-02-2006 12:37 PM
