4 jug cummins
4 jug cummins
i know cummins made a sweet little 4 clyinder engine between 83 to? at the airport where i work plowing snow in the winter theres one in the Trackless tractor no turbo sounds nice my question is dose any body here any exprice with them and was a turbo an option ? and any info on them would be great Thanks
Thanks guys , now has anyone on dtr souped one of the 4bt cummins up and how as in where to get parts what screws you can turn an so on
They take the same injectors as our 6BT's and respond to the same pump adjustments. Most are 105 to 130 HP in stock form, and are easily tweaked to 200+hp before you need to drop any coin. A lot were non-I/C, a lot more were aftercooled. They're great engines, but they're supposed to be somewhat unbalanced and have a bit of vibration. The few stepvans I've piloted with the 4BT's in them seemed pretty smooth, though.
Riflemanusmc is correct on the height. Dry weight on the fully dressed motor is about 800 lbs. I cannot remember the length off hand but I can check tonight when I get home.
xxwildbillxx
08-19-2011 09:25 AM
ProjectM880
12-01-2004 06:40 PM
