Sponsored by:
Sponsored by: CARiD
2002 ho dodge,2500,6 speed
Old 02-23-2005 | 01:38 PM
harry j holcomb's Avatar
Cool 2002 ho dodge,2500,6 speed
My son has a 2002 HO dodge cummins, with 6-speed. He says that you can
pull horses, whatever, up hills or whatever. He has seen no advise not to in his manual.
I thought that you should treat that 6th gear much like you do in 47RE auto.
Any body got any light to shed?
HJH
Old 02-23-2005 | 02:08 PM
gunracer1's Avatar
i would pull it 5th in a 5 speed, 4th in a auto and 6th in a 6 speed, it won't hurt anything. the 5 speed is a bit dangerous to pull below 1500 rpm, because the 5th gear nut could spin off.
Old 02-23-2005 | 02:37 PM
WhiteSport600's Avatar
Definitely use 6th. The NV5600 is a heavy duty trans designed to pull. There are many trucks on here that have over 300k on them and have pulled huge loads in 6th the entire time... This isn't a light truck that needs to be babied, besides top speed in 5th will DRINK fuel and your limited to max 55-60mph... Don't worry about the tranny, it'll pull anything you want.
Old 02-23-2005 | 06:44 PM
graphitecumnz's Avatar
echo syndrome... this 6-speed is as stout as they come. 5th gear @ sustained highway speeds(65-70) is going to drink fuel by the gallon/mile...
Old 02-26-2005 | 04:19 PM
96_12V's Avatar
The torque curve on this engine reveals that it's better off a bit lower on RPM's as well. Sort of the opposite idea of a gas engine. The 5.9 is best off being left lower in the revs as much as possible.
marksblaster
10-27-2012 12:26 PM
mr280zxt
11-29-2009 11:12 PM
joebishop23
10-29-2007 11:19 AM
johnlo
18
10-24-2006 11:58 PM
