18 PSI oil pressure at idle..?
I posted a similar topic in the 12V section, but it's not getting many hits. Short story is that after 80 miles of interstate driving, running Rotella Synthetic 5W-40, I got a low-oil-pressure warning light at idle. The "inaccurate" dash gauge read just under "40." Only happens when fully warmed up, 45 minuites of driving or more.
Hooked a real gauge onto the 1/8" NPT hydraulic port on top of the oil filter - and with the engine hot (but the light not on) it read a solid 18 psi. High idle is about 65 psi, 1800 rpm about 45 psi. "Cold start" (85* F) at idle it was at 50 psi. Does anyone know the Cummins low-acceptable pressure at idle with the engine warm?
I'll probably switch back to Rotella 15W-40 mineral oil - it's always worked fine. Thanks for any help...
Sounds right. On my engine after the oil was nice and warm it was around 20psi (rotella 15w-40). Cruising down the highway around 1700-1800rpm it was around 45-50psi. WOT it was ~60. On a cold morning though it would peg my 100psi gauge at idle.
So do the stock sending units read high at idle, and maybe low at WOT? Mine went out a while back,and the new one reads lower than the old one at all times. I want to stick a gauge on the port and see what I really have.
Eric
Eric
38 Cigarette
16
08-28-2015 11:27 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
