Sponsored by:
Sponsored by: CARiD
12v into a 73-87 Chevy Question
Old 08-13-2006 | 08:43 PM
csramsey640's Avatar
Has anyone ever swapped a 12v into an older body Chevy pickup truck? A friend just purchased a 12v from a doner truck and would like to swap it into his 1984 c30 crew cab. What problems did you have with firewall clearance, and what was needed for it to fit?
Thanks
Old 08-13-2006 | 10:10 PM
BearKiller's Avatar
They can answer your question over here:
www.Cummins-Conversion.com
Old 08-13-2006 | 10:27 PM
derek840378's Avatar
Thanks
there are members here that have done it. do a search and see what you can come up w/. these trucks did have an inline 6 but nothing near as big as a cummins. motormounts would have to be fabbed, and adaptor w/ be needed if want to used the stock tranny ( most likely a TH400).
Old 08-13-2006 | 10:41 PM
BowtiedCTD's Avatar
motor mounts need to be fabbed. dont go with a chevy tranny unless you go with an Allison torque converter plus the adapter is expensive, i sold the one off my truck for 800. if you dont want to lift the body you can put the motor on the bottom of the frame but if its a 4x4 you will need to lift the truck or cut the oil pan up to have clearance. when i had the auto behind mine( TH350 and TH400) it eventually turned the TC into an internal slushy. any other questions let me know cuz i am giong to have to redo mine this winter since the person that installed it in my truck did it half edit. good luck
SRobertson
02-07-2012 12:38 AM
racinrex
06-04-2009 12:54 AM
BigDiesel396
Cummins Conversions
05-16-2008 02:52 PM
BigDiesel396
11-03-2007 06:46 AM
95black2615
19
05-24-2006 11:05 AM
Quick Reply: 12v into a 73-87 Chevy Question
