WVO and trans fat
WVO and trans fat
hello,
know nothing about running alternative fuels but there is much to do about NYC banning food with trans fat oils. heard on the news that los angeles will do the same and all in the interest of health.
don't care about the health issue but wondering if this new oil will affect the way trucks run on WVO.
at some point in the future my truck will be converted but not for a number of years. just wondering.
thanks
david
socal
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
thanks
david
socal
just off the top of my head, I thought trans fats were related to hydrogenated oils... and hydrogenated oils were bad for bio...
it made the cold weather performance worse...
plus your engine mysteriously gained weight...
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
From what I have heard they will be forced now into using pure oils such as corn and peanut which are far easier to run in a WVO set up or as a mix. Don't quote me though. I think it may be a good thing.
here in Colorado, winter performance is better if you avoid hydrogenated oils..
check here: http://journeytoforever.org/biodiesel_yield.html
look for "Oils and esters characteristics" for information on different oils...
then here's what I was looking for:
"Hydrogenated oil, shortening, margarine
When oils are hydrogenated hydrogen atoms are added to the carbon-to-carbon double bonds in unsaturated fatty acids, which then become saturated. This results in higher melting points. Fully hydrogenated oil is solid at room temperature, partly hydrogenated oils range from liquid to creamy to solid.
So biodiesel made from hydrogenated oil is less likely to oxidise and polymerise but will have a higher melting point than if it were made from unhydrogenated oil of the same kind. It increases the risk of filters plugging in cold weather or even just cool weather and is best used as summer fuel."
so it's actually better, if you can take the higher melting point...
04ctd
03-08-2006 11:22 AM
