veggie conversion
What do you want to know? I run it in my 04 Dodge and know lots of others in all kinds of vehicles including 12v cummins p7100 trucks as well as 24V vp44 trucks.
Your injectors may be borderline for VO use.......
Are you looking to do a two tank coversion where one tank if for diesel and the other is for VO?
If you have a FASS system already you cannot run straight VO through it unless it has the larger motor on it. Only certain models have the larger motor. If you have the 45psi model for the p7100 12v trucks then you probably have the right kind. If you have the ~18psi version for a 24 valve then that one will not work.
basical two tank system components are:
Tank
heated fuel pickup
VO pump
heated filter
final heat exchanger
selector valves
fittings
hose
etc.
Tank
heated fuel pickup
VO pump
heated filter
selector valves
fittings
hose
etc.
murphy i have looked at building a bio processor
what about the boiler i would like a outdoor multi fuel furnace that could burn wood and wasteoil can your furnace burn glycerin
Begle1
04-25-2006 08:58 PM
