Pex tubing & chemical resistance ?
I am trying to nail down a flex tubing to use in building a processor for bio diesel , needs to resist the vegi oil , methanol , lye and maybe acid .
I am getting some info about as many as 6 or types of Pex tubing .
But know body at any of the hardware stores know about much , also once I find out what kind for sure , where to get ?
Thanks John
Thanks John
i would find a local plumbing supply store. They would have the best knowledege of what your looking for and are more likley to have it in stock that any general hardware store
You guys missed the boat by a mile , I said I had been to a hardware store [ a pros store ] , and a few others , they do not know much beyond general house hold use .
Thanks anyways John
Thanks anyways John
Thanks John
Thanks John
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
Best site I have found for anything bio related. Hoses and tubing when making bio take a beating. Think of the hoses as regular maintenance items. They will not last forever.
I go there a lot , there answers are all over the place , works / doesn't work , with no links to there opinions .
I am not on either side of the right / left political world , but that site leans heavily to the left , and the left does not seem to go by science / facts , but what they believe [ thats the right also ] .
When I go to the bar , the only things I talk about are religion & politics , aways stirring the pot .
But thanks .
But thanks .
John, have you tried McMaster-Carr? They carry all kinds of tubing and hose. I've ordered Teflon(PTFE) and Viton B tubing from them. Check with their sales people - you might find someone who knows something.
If you are thinking PEX pipe, I have been using pex for about 4 years on my boiler drain. The problem is not the PEX pipe but the connections. They get eaten away by the acid in the condensate from the two drains. The connectors for pex are just brass and don't last a year. I have tried looking for stainless but no one seemed to carry what I wanted. I have since switched to one continuous piece of pex for each drain and no connections at all. Home Depot carries 1/2 and 3/4 inch inside dia PEX.
Location: Smith Valley, NV (sometimes Redwood City, CA)
I've been using PEX in radiant systems for many years.
The main thing to watch out for is chlorine over 4 PPM, exposure to sunlight for extended periods and temps that are too high. If is sees occasional sun and it's not under pressure you might be ok, but use barrier PEX for better protection. The "barrier" prevents oxygen permeation through the tube wall but also helps with UV degredation. Pressure and temp ratings are 180 degrees F at 100 PSI.
It dosen't seem to be rated for contact with oil but it is what gas cans and natural gas piping are made of. Maybe a slightly different formula.
If you expose it to high temps occasionally and it has any pressure it may soften enough to let go. No steam or superheated oil for any length of time or with any pressure. No chlorinators that may give it a high dose.
I don't recommend plastic fittings, but if the pressure is low and you find some that are really good, they might be OK and best for keeping chemicals away from metal. I've seen some glass filled ones that seem OK, but I've also seen some I would not trust.
For more information go to www.zurn.com
John
John
It seems that most replies are not relating directly to the specs of use , the oil being waste vegi oil , the chemicals being 20% by volume of methanol & 1% lye , added info is pressure not over 100 psi , heat should not go over 180*F , but typical temp about 145*F .
This all for building a bio diesel processor .
Thanks guys .
Thanks guys .
John,
If you want the final word go to the Zurn website or other manufacturers sites. You'll always get more detailed info there than from those of us that use it but may not know much about you're particular situation.
Or just try it and see. It should work just fine for the parameters you describle. What else can be said?
John
John
I've been to several of the different manufactures sites , hard to find info on specific use that I am referring to , being that it may be a new use for a moderately [ 20 yrs ] new product , and I am in the bio-diesel forum , I thought that I may find some info here , maybe someone has done used it for this purpose .
redneck2thamax
06-06-2008 07:50 PM
SoTexRattler
04-28-2005 12:47 PM
