New Ultra Low Sulfur Fuel
I just received this in a newsletter from Cummins, (see the link below). I wonder what you guys make of it. Other than the stated loss of fuel efficiency, do you think it will have a detrimental affect on or Injector Pumps? Lubricity, Longevity? Do you think it will make it absolutely necessary to use additivies?
http://list.priceweber.com/cummins/td/ulsd.html
I run Stanadyne already and called them to see if they were modifying their addative for ULSD. They said they were not, but that when california went to ULSD the number of pump rebuilds in that area tripled. They are also selling ALOT more of the strait lubricity additive. The party line is that the ULSD won't hurt your truck........
Engine oil effected too
I saw that the other day and noticed...
"A new CI-4 engine oil is being introduced, with a new formulation designed specifically to work with ULSD fuel. If you run with a pre-2007 engine oil (such as CH-4) and ULSD fuel, you will have to modify your oil change schedule."
Originally Posted by 6speedcowboy
why is there a need for a different oil with ULSD?
The CI-4 oil has been around long before ULSD. My bet is most of us have been using it for years. CI-4 was designed to hold more soot that the common rail engines produce.
If anything using CI-4 will extend your oil change intervals.
My question is;
Do we now have to use MORE lubricity additive that the norm??? Than we were originally using?
I always use Lucas, because I've not found a supplier for stanadyne, all the truck stops seem to have Lucas and NOT stanadyne. And that's where I get my fuel, either Flying J or Love's.
Just add a couple gallons of burnt motor oil to your tank & you will notice a better running motor because of the lubricosity of the oil. I am running a 25 %
mix of burnt oil & 75% red or off-road fuel. Sure I am an outlaw, but it works & saves me currently 60 bucks or so a fill up between my truck & transfer tank. If nothing else go to Walmart & buy a gallon of the cheapest 2 stroke oil, Walmart brand & pour that in your tank. It works very well.
I didn't thinkl there was a whole lot evidence to support the statement that low sulphur fuels did not "run good".
I thought the lubricity thing always had to do with the VP44 and nothing else.
Are there old 12v motors going to hell because of low sulphur???
Originally Posted by Silverjay
I have a bottle of Delo and Rotella in the garage and both of them have CI-4 ratings already on them. I bet they are not the only ones...
I talked to a friend of mine in McDonough, GA yesterday that does a lot of Diesel Performance work. He said just in the last week alone he has seen numerous vehicles dying from the ULSD. He mentioned to me a fleet of about 55 buses I think it was, that is leaking diesel on everyone, after they took their first delivery of ULSD> He said there have been numerous people call him about problems with their injection pumps after running their first tank of ULSD. All makes & models he said. This really should be a concern. I will definetly continue to burn waste oil mixed in my diesel. It seems the common problem among all of these vehicles is pump seals leaking, based on what he said. Some of you probably know who am referring to, so you know his reputation & can definetly respect his findings & opinions.
