Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
MUST READ Web site - Tips for improving MPG
Old 10-28-2005, 10:38 AM
Black 03 2500 C's Avatar
Thumbs up MUST READ Web site - Tips for improving MPG
Guys,
I was told about this web site, thought I
would share it.
you must Copy and paste for it to work.
www.smartgas.net
steve
Old 10-28-2005, 10:44 AM
displacedtexan's Avatar
The link works...
Old 10-28-2005, 12:43 PM
VADSLRAM's Avatar
Acetone??
Has anyone here ever tried it?
It's such a great thinner, I've used it to clean carbs but never put it in on purpose. I worry about it eating the inside out of my fuel system.
Old 10-28-2005, 04:09 PM
truckjunkie's Avatar
Yeah - I'd be interested in this, but has anyone really tried it? The authors on that website do ramble on and on, don't they???
Old 10-28-2005, 04:17 PM
P.J
P.J's Avatar
I'm suprised at what their opinions are on Octane #'s for Gas? Seems they think the Lower the Octane, the Better the MPG'S?
Can't say I've heard that one.
Old 10-28-2005, 06:15 PM
04ctd's Avatar
did my homemade Timing Sensor last week...wow...MPG looks to be up 2mpg.
had 18 showing today..was 15 16
Old 10-28-2005, 08:33 PM
triplenickel's Avatar
While I'm certianly no engineer it's my understanding that a higher octane just means the fuel is more resistant to burning. Hence using it in high compression, or crazy advanced timing engines with detonation issues. So maybe if low octane burns easier it will burn more completely? Just thinking out loud with the last sentence.
Old 10-28-2005, 08:34 PM
runamuk's Avatar
Yes I've tried the acetone trick with less than 15k on my truck. I gained 1.5 mpg.
I will continue to use it kind of like a carburator and fuel system cleaner at the rate of 3oz per 36gal tank full. With that ratio. I will not use it on a continuous basis for lack of research as to what it does to my plastic parts and seals.
Great website BTW very informative!
Rick
Old 10-29-2005, 06:49 AM
j-fox's Avatar
Guys, on a gas motor, any octane above the minimum needed to resist knock is a waste. Slow to light fuel is like retarded timing.
I have tested the idea and believe it.
Any increased mileage from a fuel with higher octane is from a better fuel that has a higher BTU content.
Old 10-29-2005, 07:07 AM
Boatnik's Avatar
Well I dumped 4oz. pure acetone in my yota yesterday evening and 6oz. in my DC. I won't be able to give mileage results on the truck since I haven't fixed/replaced the odometer, but I will have meaningful numbers on the '95 Toyota Camry 4 cyl. in a couple weeks. I have been getting 28 mpg just running regular gas. The valves have never been adjusted and it has 130,400 miles on it.
Old 10-29-2005, 10:09 AM
Smokee's Avatar
I dumped in about 15 oz for 60 gallons. I am going to be towing a thousand miles or so next week and I will let you know how things go.
Old 10-29-2005, 10:45 AM
Geico266's Avatar
It says right in the article not to use acetone with plastic. Our fuel tanks are plastic remember?
I'm gonna sit out this one until we have solid evidence of compatability.
Old 10-29-2005, 11:26 AM
Fronty Owner's Avatar
6. Use Warm Air Intake: Modify intake to draw warm air near radiator.
Advantage: Deliver warm and smooth air to the intake for best MPG.
Directions: Disconnect the cold air hose or housing from the fender well. Remove filter. Clean up the parts. Bore about 10 1-3/4 inch holes into plastic housing (if this applies) to draw air from the engine compartment directly to the air filter. Deburr the holes and clean the parts. Plug up the cold air inlet leading to the air collector box. Reinstall the air filter assembly. This will improve the engine Thermal Efficiency and mileage
Lets see, acording to what I remember from thermo, the greater the temperature change, the more work done in that cycle. so if your bringing in 200 degree air and raising the temperature to 1000 degrees, your doing less work than using 50 degree air and raising the temperature to 1000 degrees.
Old 10-31-2005, 06:30 AM
VADSLRAM's Avatar
Warm air is better for milage?
Then why do I have an intercooler??
Cool air= denser charge= more heat from compression and more molecules of burn assisting oxygen SHOULD equal more power and more milage.
Old 11-01-2005, 07:27 AM
bluebull's Avatar
Guys, we have an intercooler in the air intake system, so unless you take that out of the picture it doesn't matter how you plumb the intake.
I read on another site where a guy was claiming that if you block off half of the air intake so the turbo could build more heat on the intake side it was by fact to increase MPG yah right same thing there, he still has the intercooler to deal with.
Quick Reply: MUST READ Web site - Tips for improving MPG
