Jet Fuel
Jet Fuel
I have access to large quantities of "Jet-A" jet fuel, can I run this in my gen 3 or not? We buy 8000 gallons at a time and my cost would be around $2.20 per galon.
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
1 Post
I'm thinking that Jet-A is the same as JP-8. If so, I wouldn't run it. It has even less lubrication than low sulphur #2 and is almost a solvent. It will clean out you fuel system real well. Some manufacturers will void IP warranties. It also has about 10% less "power". We've noticed a much higher failure rate on the Stanadyne IP's (6.2 and 6.5 GM engines). TACOM (Tank/Automotive Command) sent out a notice about adding engine oil to the fuel to increase lubricity and decrease pump failure.
It's your call.
It's your call.
I don't think I would run 100% Jet-A, as stated before, the fuel is too dry(not enough lubrication for the pumps). A 50-50 mix shouldn't hurt anything though. Jet-A is just highly purified(filtered) Kerosene, AKA #1 fuel oil. After all, during the winter in the colder areas like here, your #2 is cut sometimes up to 35% with kero anyway. If you wanted to run a 50-50 mix, like I said, I wouldn't worry about anything, except your fuel mileage dropping some, and run a good fuel additive like Power Service or Stenadyne to help with lubricity. You don't have to worry about the taxman either, as you probably know if you're buying the stuff, by law Jet fuel can't have any dye in it, it's clear.
Josh
Josh
