bio # designation?
bio # designation?
i keep reading these posts about biodiesel with reference to things like "B20" "B100" "B99" and so on. what is the significance of these numbers?
Originally Posted by LanceD
I believe that is the percentage of biodiesel mixed with regular # 2 diesel. so probably for B20 it would be 20% bio and 80% #2 diesel and so on.
LanceD is correct. B20 is 20% bio-diesel mixed with 80% regular petro diesel. B100 is 100% bio-diesel, no petro diesel mixed in at all. Every other number (B1-B99) though is the ratio of bio-diesel to petro diesel.
I am not going to claim a lot of knowlage here but the centane is higher , around 50 as compaired to 40-45 for dyno oil, and I've heard that the molicues are larger for bio [ maybe larger or more holes] , so it seems to me just like racing & reloading tune for conditions.
Originally Posted by jeepsuck
that makes sense.
now for round 2.
i've been told that in order to run %100 bio it is required that you change your injector timing, is this true?
now for round 2.
Depending on the price difference between BD and #2 it may be more economical to run more of a blend. That's much of the reason B5 and B20 is more available than B100.
Bio in the cold
Originally Posted by infidel
No need to change the timing but if you run B100 you will have less power and won't get as good of mpgs.
Ken
the reason i ask about is because if I were to make bio at home it would be awesome to give big oil the shaft and run 100% BD. but if i had to run a mix it would still save me money, which is #1... right after shafting big oil
Wvo
http://www.frybrid.com/test.htm
http://www.frybrid.com/forum/
http://biodiesel.infopop.cc/eve/ubb....51&f=159605551
If you are a chemist you will enjoy Bio-diesel, I'm more mechanically minded and use WVO. Each seem to work OK, each have their draw backs. Both are worth looking into. However a word to the wise about using WVO; Filter well, de-water, and never burn cold oil, easy to do. Feel free to drop me a PM or e-mail. E-address - akghound{at}onewest.net
Ken
snowmanx
03-23-2010 11:23 PM
