fuel is leaking everywjere! Fuel Heater top quad ring gasket toasted
Old 10-22-2009 | 06:09 PM
jesussaves's Avatar
Ive got the new gasket but cant get to it? How can you get the filter stud off to access it?
Old 10-22-2009 | 07:27 PM
jesussaves's Avatar
i should have searched i found i need a 9/16 drag link socket
thanks
Old 10-22-2009 | 07:29 PM
Or a really wide screwdriver, or a stiff putty knife, or a cold chisel you don't care about grinding on...
Old 10-22-2009 | 09:17 PM
MoPowa's Avatar
where'd you find the gasket? I just found mine leaking as well.
Cheers
Old 10-22-2009 | 09:21 PM
jesussaves's Avatar
3834185-S is the part# its only available at a cummins parts supplier, the incredible hulk must have put mine on I have spent all night trying to get it off and it hasnt bugged and its just stripping the slot
Old 10-22-2009 | 09:25 PM
jesussaves's Avatar
is this a reverse thread?
Old 10-22-2009 | 09:38 PM
rebal's Avatar
no righty tighty
Old 10-22-2009 | 10:42 PM
ofcmarc's Avatar
I believe that Bearkiller found that a spade type drill bit worked well. You can also get a wrench on the shank for a bit of leverage.
Old 10-23-2009 | 01:16 AM
Chrisreyn's Avatar
Originally Posted by rebal
no righty tighty
only if you lay down under the truck and are looking up at it
Another trick to try before buggering it up to badly is getting two nuts that will thread onto it.. use one as a lock nut against the other and turn it using the second one.. I did this a long long time ago on my first 91 to tighten the stud, mine kept spinning off with the filter!, but I dont recall at all what the size/pitch were...
Old 10-23-2009 | 01:21 AM
dieselnut416's Avatar
knowing cummins its metric but it is filter side i took mine off with a set of needle nose vice grips there the stud goes into the housing while i was trying to spin the housing
Old 10-23-2009 | 01:53 AM
Chrisreyn's Avatar
Thread Size: 1-16 ~ thats what the filter that threads on there is, so that must be what the nut size was too!
I do recall I got the nuts through Fastenall..
Old 10-23-2009 | 02:07 AM
dieselcrazyw350's Avatar
i tried getting my seal from the dodge dealer before i took my fuel heater off and turns out they gave me some random other seal which there was no way it was gonna work so i just took the fuel heater off and took the old seal and put oil on it and put it all back together and it stopped my leak
Old 10-23-2009 | 08:15 AM
jesussaves's Avatar
I totally misjudged the time on this one, thought it would take 30min Working on 2 days now
Old 10-23-2009 | 11:04 AM
NotEnufGarage's Avatar
Cheers
I got mine at the local Dodge dealer parts department. $2.50 out the door.
I used a 3" long piece of 1" flat steel, ground the end down like a screwdriver and bent it about 9" from the other end as a handle to get the bung loose. Worked like a champ on a 4x4, not sure on a 2wd, though.
Old 10-23-2009 | 02:42 PM
jesussaves's Avatar
got it changed out!!!! Thanks for all the advice everyone it helped alot!!!I love this site!!!
Quick Reply: fuel is leaking everywjere! Fuel Heater top quad ring gasket toasted
