fuel filter failure
fuel filter failure
Hello,
I've been a lurker for a while but this is my 1st post and I'm looking for insight into this problem.
My son's 2008 3500 (~130000 miles) just sustained injector and other damage when a fuel filter replacement collapsed letting crap get by into the injectors and elsewhere. This replacement fuel filter (spin on type) was suggested by the dealer and my son ok'd it. The filter was clogged (and subsequently collapsed) by bad fuel (algae according to the dealer) from a very recent fill up.
Has anybody seen something like this. I can't believe that a filter can would collapse when clogged. Of course the dealer is blaming my son for not changing the filter often enough ... which may be true ... but should a filter fail catastrophically like that? I blame the dealer for using an inappropriate part. Am I wrong?
He's looking at roughly $6k repair bills. Thanks for any insight into this.
Peyton
Peyton
My son took a fuel sample from the filter so it should be a good one. I haven't seen the filter yet but I plan to take a photo this afternoon. So far I'm relying on my son's description.
Peyton
Having said that I have seen a ton of guys get hammered by the Dealers for bad fuel when there wasn't anything wrong with it.....seems to be the "go to" excuse so they don't have to warranty something any more.
Test your sample and then you will at least know where you stand and whether you need to get aggressive on Chrysler or not.
Best of luck to you
Im with Top on this one.
I love my Glacier Diesel 2micron setup. Cheap cheap cheap insurance compared to a 6k repair bill.
I wish you the best of luck trying to get everything sorted out.
good question. there is no number on the element. it is a pleated paper filter that goes into a plastic cannister. the mechanic said it was a double element type (15 and 5 micron). it had collapsed into a partial hourglass shape.
does no part number = proprietary?
Peyton
Peyton
Are you talking about the upgraded OEM filter? If so the only way that would happen with a stock lift pump is improper installation, so who installed it?
The OEM pump cannot collapse a OEM filter, even if the filter is plugged.. the fuel will just stop flowing. Even if the pressure regulator in the tank failed the psi would not be enough to do what you described.
It sounds to me like impropper installation to me. There is no way that a dealer would take blame on something like this. I have never, ever, found a dealer to be honest all the time. Especially in the maintenance department. Where I live, the majority of the mechanics are failures at their jobs. I have seen so many mistakes when performing basic maintenance on our Diesel trucks that I would never take mine to the dealer. As far as I am concerned the warranty is useless anyway. Not the case everywhere but where I live that is my experience.
I am anxious to see how this works out for you though. How is the maintenance bill 6K though? What is the dealer saying has to be replaced? For 6K you could get a new 6.7L Cummins off of Ebay with low mileage. That's what I would do.
Unless some crazy stuff happened there is no way the engine can pull enough vacuum to collapse the filter without the engine starving for fuel. As for the so called algee build up my fuel filter is black after 8,000 miles of use if that is what they are going off of on bad fuel. I would fight this for sure and get that fuel sample.
At 130,000 I don't see how there is a warranty left anyway. maybe an extended warranty?
If the dealer installed the filter, they should have a record of what/when it was installed. I agree with above posts, most likely an improper install and seriously doubt the dealership would own up to that being the cause.
As for repairs, I'd get it done for probably half or less @ somewhere other than the dealer.
jeff.
jeff.
AH64ID: Are you talking about the upgraded OEM filter? If so the only way that would happen with a stock lift pump is improper installation, so who installed it?
Rednecktastic: Was it running rough prior to collapsing?
New2Diesel: It sounds to me like impropper installation to me. There is no way that a dealer would take blame on something like this. I have never, ever, found a dealer to be honest all the time. Especially in the maintenance department. Where I live, the majority of the mechanics are failures at their jobs. I have seen so many mistakes when performing basic maintenance on our Diesel trucks that I would never take mine to the dealer. As far as I am concerned the warranty is useless anyway. Not the case everywhere but where I live that is my experience.
bdewey: Unless some crazy stuff happened there is no way the engine can pull enough vacuum to collapse the filter without the engine starving for fuel. As for the so called algee build up my fuel filter is black after 8,000 miles of use if that is what they are going off of on bad fuel. I would fight this for sure and get that fuel sample.
jeff-kc99ftp: At 130,000 I don't see how there is a warranty left anyway. maybe an extended warranty?
He and a friend feel that they can do the work themselves but I am trying to dissuade them. Thanks for all the support.
Peyton
The fuel pump is in the tank, so it won't suck anything! The CP3 can draw fuel but not enough to do that to a filter than is designed as a pressure filter.
If you did get contaminated fuel you may check with your insurance, it's normally covered.
15 psi is the normal operation pressure for the factory pump.
Under load it drops to 12.
Now way in heck that factory pump caused the filter to collapse.
