1st Gen 4 door Project w/ Pics
Old 07-03-2008 | 09:49 AM
  #31
Mcmopar's Avatar
Troop,
Do you think you could fit a 2nd gen radiator and intercooler, along with the A/C condenser in there and still use a 75 grill? That's what I want to do with my crew cab. I'm still collecting parts right now.
Old 07-03-2008 | 08:59 PM
  #32
Trooperthorn's Avatar
Originally Posted by Mcmopar
Troop,
This is exactly what I want to do. I have all the parts. Since it will be a 5-spd I won't have to worry about a tranny cooler.
I do not know the answer yet. The 2nd gen intercooler is thicker and the clearance was pretty slim with the 1st gen cooler. I also need to check to see if the condensor will fit in the hole between the rad and the cooler if you cut out the vertical bar. I will look at it tonight.
Old 07-04-2008 | 03:39 AM
  #33
Bruiser, sorry for the hi-jack.
Looks like the ac condensor will fit inside the openning between the rad and the IC if you cut out the bar. The second gen intercooler is only 1/4 inch thicker, but it is consideably wider than the 1st gen. For the '75 grill, some trimming on the lower valence would have to happen.
The edge of the 1st gen intercoller is touching the valence at the bottom of the cut-out.
Old 07-04-2008 | 08:20 AM
  #34
Mcmopar's Avatar
Troop,
Keep me posted if this realy fits, my crew is really pretty clean and I want the total vintage look. I am going to do the hydro boost and P-7100 setup.
Old 07-19-2008 | 05:11 PM
  #35
BRUISER's Avatar
ya ya ya...
Well today and tomorrow are the only days I have had planned to work on the dodge so I am right on MY schedule
I got all electrical, hoses, connections off truck today except a few things.
So tomorrow I will be taking out radiator, intercooler, a/c condensor.
(they are all disconnected already)
I would have had it all out today but I can not find a tool I need. so I gotta go for a drive and borrow one..
pss.. here I come John
Old 07-20-2008 | 01:23 PM
  #36
BRUISER's Avatar
Well I got a bunch done this morning
I got the rest of front clipoff
then I decided to see if I could get the engine out by myself..
well hey I guess when you are motivated youcan get a lot done by yourself
Old 07-20-2008 | 01:27 PM
  #37
BRUISER's Avatar
So next is to wash the engine and get it all cleaned up..
Old 07-21-2008 | 01:52 PM
  #38
Mcmopar's Avatar
Pictures of the engine mounting holes in the frame and the motor mounts would be awsome!! Are the 85 and the 92 frame mounting holes the same?
Old 07-21-2008 | 02:24 PM
  #39
BRUISER's Avatar
they are exaclty the same..
the 85 even has the motor mounts still in it.. and they look perfect but I am gonna replace them with new ones.. not worth the risk
Old 07-21-2008 | 11:41 PM
  #40
Mcmopar's Avatar
Sweet, can you get those pictures?
Old 07-22-2008 | 10:24 PM
  #41
BRUISER's Avatar
pic of empty engine bay
Old 07-22-2008 | 10:26 PM
  #42
BRUISER's Avatar
close up of motor mounts
Old 07-22-2008 | 10:31 PM
  #43
BRUISER's Avatar
here is mount on engine side
Old 07-26-2008 | 09:59 PM
  #44
BRUISER's Avatar
Well Today was a GREAT day and a Bad day..
I was supposed to go wheeling at the VT Memorial ride in VA but due to family and other things I was not able to make this trip
So I contacted some buddies and we got to work on the Dodge.. which made it a great day..
We got engine, tranny and transfer case in and all mounted up
we almost got the driveshafts in but the u-joints need to be replaced..
lots of pics..
Old 07-26-2008 | 10:01 PM
  #45
BRUISER's Avatar
I got front clip off, the old exhaust out, old fuel lines out, and a bunch of other small things out prepping for the drivetrain
