rediculously modified, how do they do that?
Old 12-29-2005, 11:40 PM
stillsmokin's Avatar
I was watching a video from miller tire the other night and saw some 2nd gen dodges with twins, and I watched the schied video link . They sound more like a steam engine, than a diesel, until the turbo spools. What causes the "chugging type sound"? I've repaired stock diesel engines for years but this just has me thinking a million scenarios of what is going on in the engine.
Also, I've seen 12 cylinder pumps on 6 cylinder engines in pulling tractors how is this done without runaway. Is one set of injectors somehow turned on at full power when the turbo spools?
Old 12-29-2005, 11:54 PM
TravisG's Avatar
There is only one set of injectors w/ the 12 cylinder pump I beleive just two lines running to one injector. That pump will run ya quite a bit of $$$$$.
Old 12-30-2005, 12:25 AM
PourinDiesel's Avatar
Alot of fuel delivery timing, decompression, big cam, basically the engine doesnt want to run at the lower rpm's.
Old 12-30-2005, 12:47 AM
So the chugging in a real hot diesel is like the lope of a gasser with tons of valve overlap?
metal_miner's Avatar
I always wondered about this too! What do these guys run for EGT and water temp doing the pull? Better to put masking tape over the gauge?
Old 12-30-2005, 07:59 AM
Lower than you think.
The egt's are usually in the safe zone.
Old 12-30-2005, 08:51 AM
getblown5.9's Avatar
thats suprising, i have heard reports that the BIG hp pullers like haisley, and shied run about 1800+ on the EGT in those purpose built motors
i love when am giving my truck lots of fuel coming down the road and then let off quickly and i get that timing change in the motor as it tries to adjust itself due to the comp, fuel, air temp etc...and it will lope as i sit at the redlight until it finally gets itself straightened out...but it sounds like a mean beast there rumbling and shaking like it doesnt wanna run
Old 12-30-2005, 04:46 PM
joefarmer's Avatar
Real close, but it's more of the function of injecting fuel at very advanced timing. Rumors have it in the 50-60° range. That coupled with the fact of these engines are running low, low compression like Justin said.
brnaodn.
Old 12-30-2005, 06:37 PM
You mean like this???
Click here to see Video
Old 12-30-2005, 09:50 PM
TravisG's Avatar
Nah- thats what my truck sounds like all the time.
Happy New Years Justin. Goin to Gordyville?
Old 12-30-2005, 10:05 PM
We just had our first baby and I am on home duty right now!
So Gordyville is probably a nogo at this point.
I hope someone posts a good video of the event!!
HAPPY NEW YEARS!
Old 12-30-2005, 10:19 PM
TravisG's Avatar
Congrats on the new baby. Let your lady get her sleep. New babies are a lot of fun. They grow up quick.
Old 01-02-2006, 02:05 PM
How low of compression are we talking about, like 12.5:1, or lower. I've seen real old hand crank start diesels that are as low as 5:1 but they start on gasoline and switch over to diesel. These babys crank out the smoke!
Old 01-02-2006, 02:14 PM
I don't know its all smoke and mirrors when you get into that power arena
Old 01-02-2006, 02:16 PM
clawson's Avatar
Dang i didn't even know you were married??
Congrats Justin on the new baby.
Chris
Quick Reply: rediculously modified, how do they do that?
