P-Pump My 24v?
So what is the advantage of P-Pumping a 24v?
Is it for performance only?
If I had a 24v and converted it over to a p-pump and did no other performance mods and even left the pump is "stock" form, would the motor be more reliable or economical than normal?
If you tranny is up to the job I know where there is a rebuilt HRVP44 with 1 year warranty for sale........
But if your going to P-pump it you need to get a cam with the lobe ground for the 12 valve mechanical lift pump.
Reliability is up. But lets not forget, mechanical things fail like anything else, so it definitely isn't a cure all. You just reduced the failure rate a huge amount. Unless you come across a cheap wrecked 12v, the cost wouldn't be justified from a reliability stand point. I could have had 4 VP's for the price of mine. Thats anywhere from 1000 to 800k miles worth of VP's. But having something you can work on and diagnose without needing a computer is much better, IMO.
king5335
26
01-17-2010 07:57 PM
buddy26
16
01-14-2009 07:29 PM
wana12v
09-05-2006 05:19 AM
