How do i run faster then 15's 1/4 mile
Old 02-28-2008 | 09:56 AM
mcoleman's Avatar
Originally Posted by RowJ
Tranny rebuild, bigger turbo and some Mach 4's injectors from F-1.... HERE ..... and you'll be in the 13's. Can't say about your injectors...don't know them or anyone with them. This assumes you have a 3.55 LSD rear end and can launch in 4X4?
Ahh...I see the 4x4.
You may also have to deal with Dodges Tq Mgmt program that defuels when too much torque is being read w/o any movement. Not sure if 99's had this tranny protection feature but it prevents building boost on the line...pre launch.
Even without building boost...you should be well under 15.0 sec. with the above.
RJ
Nope, Don't have to deal with torque management or speed limiters on a 99.
Old 02-28-2008 | 10:08 AM
b.lee's Avatar
Torque converter
Valve body
More fuel pressure at WOT.
What are you EGT and Boost numbers?
I assume you have gauges since you know the fuel pressure at WOT.
Old 02-28-2008 | 04:29 PM
Mustang Eater's Avatar
what kind of trans should i get? and what converter ?
Old 02-29-2008 | 12:55 AM
Big Blue24's Avatar
Have you fiddled with your wastegate? Did you install the little brass elbow that came with the Juice? How much boost are you seeing on the attitude monitor?
Old 02-29-2008 | 01:49 AM
Kman9090's Avatar
I would not trust the edge monitor for 1/4 mile times. I have not seen a monitor that is eeven close with 1/4 mile times. My outlook monitor says I ru a 16.8 at 95 mph. Which isn't even close at all. I have also raced an 2004 mustang GT and am Right at his door.
Old 02-29-2008 | 07:37 AM
RowJ's Avatar
There are two or three safe choices out there today. You need to do your homework and find what works well for you. Do a search... lots of good solid info around, even ignoring all the "I love mine".... "so and so is great to deal with" comments
Good place to start is HERE
RJ
Old 02-29-2008 | 11:44 AM
JIT's Avatar
JIT
If your tranny is still working properly this should get you another second or so...
Torque Convertor
Valve Body
SMARTY
FASS or Holley Blue Fuel Pump & Big Line Kit
I gained over a second with the SMARTY alone! (thanks Brad)
Old 03-02-2008 | 02:07 AM
xOmertAx's Avatar
In my opinion, your tranny will be the next thing you do weather you want to or not haha. Dodge auto's cant stand much power.
Old 03-02-2008 | 05:43 PM
BigB82789's Avatar
Torque Convertor
Valve Body
SMARTY
What setting was that on?
Old 03-03-2008 | 09:39 AM
I am running 36 lbs of boost WOT and around 1200 to 1300 on EGT
I raced my brothers mustang which is a 94 GT with a 5.0 and we were side by side intell i hit O.D and then i pulled him 2 cars lengths he was ******
On 1/4 mile i went from 16.8 on the edge box to a 15.8 with the 100 hp injectors
Old 03-03-2008 | 09:44 AM
JIT's Avatar
JIT
# 8
Old 03-05-2008 | 03:00 PM
c12h26's Avatar
I have a 91 D250 with a bone stock 727(3 speed)that has over 260,000 miles and runs in the high 13s
Old 03-12-2008 | 10:35 AM
iracemx6's Avatar
Exactly what I was going to say!
You can't go by the monitor for TRUE 1/4 mile times because it is not accurate.Go to the dragstrip and see what's up...I'll bet you are faster than you think.
Old 03-12-2008 | 11:17 PM
fmxr47's Avatar
yeah even beefing up the tranny can increase you ET. cause it allows for the power to be delivered faster, get a good triple disc torque converter. and some nice clutches kevlar bands and all that good stuff
Old 03-13-2008 | 01:52 AM
Kman9090's Avatar
If your pulling 2 cars on a Mustang Gt you are in the 14's.
Quick Reply: How do i run faster then 15's 1/4 mile
