grabbed a new best at the track
Old 09-26-2006 | 01:30 PM
fredw's Avatar
went to the track the other night with the dual fueler and a different tune, air was equilant to 3500 feet, truck weight of 7030lbs, did a best of 12.26@112.2mph with a 60' of 1.64 on #2....
final pass added a small shot of nos and did a 11.87@ 117.3mph with a 1.74 60'... my shifts were a bit lazy or i think a .3 could of came off of that
i think fine tuning of the tune will help the number 2 passes, bit to much smoke for me, sad thing is the track is closed for the season
offer a special thanks to PPE for the best dam dual fueler, BD for the turbo, Westers for the tuning, Suncoast for the tranny, and GM for the motor
Old 09-26-2006 | 01:46 PM
natlchamp2k4's Avatar
Congrats on the time man. How much bottle did you use?? How much do you plan on using.
Even though its a dura, I just like fast powerful diesels.
Jamie
Old 09-26-2006 | 03:07 PM
HappyGA's Avatar
I think you meant to thank Isuzu for the engine.
Old 09-26-2006 | 04:43 PM
XLR8R's Avatar
Wow - what truck was that? Seems pretty light weight....
Old 09-26-2006 | 08:03 PM
wap's Avatar
wap
Congrats, thats pretty quick for any truck in my book.
I like seein hopped up fords and chevys, if we all drove dodges life would get kinda borin.
Old 09-26-2006 | 08:14 PM
streetsmoker's Avatar
I would like to know more about this "little shot" of nitrous also.
Old 09-27-2006 | 02:09 AM
fredw's Avatar
had a .040 jet sise comming on at 16psi boost, felt like it picked the truck right up, but still running a black streak behind it the other driver said in the other lane
as for weight removed it had one battery removed, spare tire and back seat removed
Old 09-27-2006 | 08:01 AM
mcoleman's Avatar
Dang nice improvement for a .040 jet.
Old 09-27-2006 | 09:14 AM
Don M's Avatar
DTR Advertiser
Great job Fred!!!
Don~
Old 09-27-2006 | 10:58 AM
king d's Avatar
once again fred nice runs ....
Old 09-27-2006 | 08:02 PM
fredw's Avatar
thanks again, but nothing like your 10.4 second duramax, gotta be the fastest truck out their
Old 09-27-2006 | 11:59 PM
joefarmer's Avatar
Like mentioned before, .040 seems a small-ish jet. Did you happen to datalog any of the runs? I'm curious what the n2o did for your intake temps? What was OutsideAirTemp? I've found that my truck is very sensitive to OAT. Sensitive enough that a .050 jet was enough to stall the engine at lower RPM on a 55F night and bearly enough to spool the charger on a 85F night.
brandon.
Old 09-28-2006 | 12:05 AM
fredw's Avatar
this was my last run and temps were droping quickly maybe 44degress
i have ran up to .125 jet a few weeks before but with out the dual fueler and the best i could do was a 12.3 with a best on diesel of 12.78
the dual cp3s have been the answer for the fuel problem, or lack of holding rail, now it is back to the lack of air problem, but the .040 shot of nitrous really kixcked it in the a22
Old 09-28-2006 | 09:20 AM
XLR8R's Avatar
brandon.
I've noticed that my common rail doesn't seem to run much differently due to OAT changes (actually seems to run .5 second faster at 75* than 55* for instance), while I'm used to the gas engines (normally aspirated) being VERY responsive to cooler air.
Anyone know why this might be?
Is it because the diesel is intercooled? Or does the ECM negate OAT factors in the fuel map?
Old 09-29-2006 | 01:55 AM
joefarmer's Avatar
On the Dmax stuff there's correction maps for OAT. There's also other correction maps for baro, coolant and more that I can't reemmeber. I'm guessing Cummins has those in the computer too, but without an EFILive-type flash utility or a custom OS, we'll never know how they work.
I see a huge difference in spooling a set of twins vs. a single when the air's warmer outside. The twins don't care what OAT, but with the single it will make a huge difference how I run.
rbandon.
CTD2001
08-22-2009 10:03 PM
judge88
15
04-08-2007 11:34 AM
rockjeep73
Competition / Pulls / OffRoad
14
12-01-2006 08:36 PM
RamWheelsBy4
09-08-2006 12:14 PM
rockjeep73
03-17-2006 03:38 AM
Quick Reply: grabbed a new best at the track
