Got pulled by a Powerstroke 7.3 - is my truck that weak?
His is a 2000 F-250, 7.3 4x4 short bed, ext. cab. stock
Mine is in my sig...
I started in 1st, and all 4 tires spun as he pulle dme, then I started in 2nd, and the same thing happened...
Shouldn't I have least put up a fight?
So that means his truck is stronger?
It only means that he could put more tractive force to the ground than you could. Assuming you were hitched at about the same level:
1. If you were pulling on pavement, then spinning tires are your enemy. It's the same principle as braking - a rolling tire has more traction than a sliding tire. If his truck was an automatic (you didn't say) and he didn't spin the tires, then he could put more tractive force to the pavement than you could with spinning tires.
2. If you were pulling on dirt and both of you spun your tires, his tread pattern might have been more aggressive than yours.
Either way, it's more about tractive force than horsepower.
Rusty
Rusty
Because you either have to slip the clutch or spin the tires unless you can get him moving your way immediately. The automatic can build torque multiplication through the torque converter without spinning its tires because of the fluid coupling effect - even if it's sitting stationary.
Rusty
Rusty
I like the idea of fat girls in my bed. 7.3 is really laggy ,if you got the drop on him you stared spin your tires first then he had you. brake till you hear his tires spining then ease the clutch out and drag him to the next county. But I agree with everybody else tell him to hook up to a sled . A powerjoke will live up to it's name,if something doesn't braek first
