Dyno Results.
Old 11-11-2006 | 05:24 PM
I SPEED's Avatar
Dyno Results.
On the dyno today a funny thing happened. I made more HP with my stock ECM VS. a Catcher ECM.
With the Catcher...521HP 963TQ.
With the stock ECM...531HP 977TQ.
Comments?
Old 11-11-2006 | 06:30 PM
Syndicate's Avatar
Either way I see your truck has another major problem.
BLUE *****!
Old 11-11-2006 | 07:41 PM
PourinDiesel's Avatar
Nice numbers!
Old 11-11-2006 | 07:56 PM
Luken's Avatar
That tells you which ecm to use
Nice #'s!
Old 11-11-2006 | 08:34 PM
95ram's Avatar
It's actually pretty common. I lost a few HP with the smarty also.
Old 11-11-2006 | 08:41 PM
Charlie8301's Avatar
Nice HP numbers, but it seems like the TQ numbers are kind of low?
Randy
Old 11-11-2006 | 08:49 PM
1qckdodge's Avatar
I dynoed today also with Nospin, sorry I didnt get any before #s ,but pulled my reflashed with #9 catcher and installed a van -aaken that is as old as dirt, with TST and on level 3 did 421hp, on level 5 did 485hp/982, on 7 did 496hp/989tq, the truck pulls harder with the stock ecm and barely smokes, my buds 2000 did 415 and no tq reading with the same setup as mine except he has a smarty set on 5, he tried a few more settings and lost a lil hp, we then pulled the smarty and installed a new van aaken and he did 465 with cooler temps and less smoke. I still like the driveability of the Catcher, but im gonna run this setup for awhile.
Old 11-12-2006 | 12:06 AM
XLR8R's Avatar
How can the Smarty produce less power than the stock program?
Old 11-12-2006 | 11:32 AM
CTD2001's Avatar
The smarty is all about driveability, better throttle respones ect. I have read a few times that when trucks start making big hp, close to 500, that the smarty will actually hurt the numbers rather then help them. I wish that i had a stock ecm to run in my truck and see what difference there would have been. I dynoed 526hp (549 uncorrected) and 999 ftlbs on #2 only, this was with the edge comp box for timing and the TST comp box for fueling. I made 3 more pulls with the the edge drag comp box for fueling and timing and the numbers were slightly lower 523 hp and 942 ftlbs. I had a couple of torque readings, one was 1215 ftlbs and the other was 1170ftlbs, but by looking at the chart, it seemed like they might have been spikes, but i am not positive, they were back to back readings.
Old 11-12-2006 | 12:36 PM
Bswope's Avatar
Nice numbers to all!!
Old 11-13-2006 | 12:52 PM
KVD's Avatar
KVD
What about running the smarty on somethin like #3 or #4 if you stack with the edge???
It seems that great drivabilty isn't from horsepower.
Old 11-14-2006 | 02:49 PM
Mike D's Avatar
Running number 3 works for me. I started a thread about my findings not long ago. I went from running 13.4 to 13.1 going from the higher Smarty settings to number 3. I also gained about 3 mph through the traps.
Old 11-14-2006 | 03:21 PM
Ceno's Avatar
go doug
i have a ways to go with my 389hp/759tq
Old 11-14-2006 | 03:40 PM
Patrick Campbell's Avatar
Try racing with CaTCHeR vs stock. I will bet on the CaTCHeR truck!
Old 11-14-2006 | 09:00 PM
I SPEED's Avatar
Racing with the Catcher shaves 2/10s.
JBradley500
08-30-2010 07:31 AM
crewcabxlt
07-03-2009 05:15 PM
John_P
NCDTR #18
22
07-10-2008 07:01 PM
pwerwagn
02-28-2007 03:18 AM
Rebel
04-20-2003 01:57 PM
Quick Reply: Dyno Results.
