drag racing technique
i went to the strip for the first time today, and of course i was nervous. i am just woundering if my technique i figured out on my own is good or could do better. i back in to the water box, pull up, give a little burn out (remember i have radial street tires), stage slowly, no spooling the turbo but the second time i spooled my turbo, a little after the bottom light turns yellow i floor it, and of course i spin the tires just a little. these are my results:
1st run, no spool up:R/T .319, 60' 2.293, 330' 6.434, 1/4 mile 15.438 @ 88.70 mph.
2nd run, a little spool up dont know how much wasnt paying attention: R/T .312, 60' 2.346, 330' 6.462, 1/4 mile 15.439 @ 88.71 mph
should i spool up my turbo, if so how many psi and how would i keep from spinning the tires...i have a 2wd truck. also should i race when i have close to a empty tank, today i raced with a full tank. should i take off my tail gate also?
We don't bother with the water box on street radials... and your 60's will certainly improve with traction bars!
I usually wait until I see 5lbs of boost before lighting the second yellow stage light. Once the second light is lit, it don't take much for me to bring it up to 10-12lbs where I normally launch. Of course in 2wd, you'll need softer tires in order to not light them up once you drop the hammer.
Of course!
Wheel hop is a good way to break parts, and the downward force the traction bars impart to the rear axle helps plant the tires... besides, wouldn't you rather that the CTD's torque was used to turn the wheels instead of deform the leaf springs?
