Camming up
Camming up
Any of you perf guys tried an aftermarket cam? I was wondereing what the difference in power, power curve, idle, streetability would be...
Mark.
Mark.
Originally Posted by PourinDiesel
Cams rule man.
Get one you wont be disappointed.
Increased throttle response, lower WOT egt's. More airflow and power overall.
Lowers boost levels through more efficient engine breathing.
No loping. Loping usually comes from fuel delivery mods.
Remember the same does does not hold true for diesels. The dont ingest fuel/air mixture. So the lopey idle is not going to happen with a cam. The fuel is shoot into the chamber way after intake valve is closed.
I was also told that 2 generation camshafts wont work in a first generation as they have different lift/ duration/ overlap. This could have changed but from what I have read max power will not change with the addition of a cam, lower rpms power will. Driveabitity and egt are much better/improved. Along with better spool up, less smoke. A fellow asked why did my boost fall off after the camshaft change. The answer was more overlap. Some have reported 75-100 deg drop in egt. On the nwbombers a fellow wrote that the egt reduction was caused by overlap.
Anougher fellow wrote> camshafts control air, not fuel. You change things like spool time, boost, smoke, egts. Pulling a bigger turbo on is like pulling in a cam in a gasser. It can move the power curve up and down the rpm band.
I hope that I got some of this correct and it at least helped answer a little of the post about loping. My 95 use to idle different but it was because of timing. I would thing that big injectors might also. Any of this correct Jim
Feel free to correct me, but on 12vers at least, the whomp, whomp sound made by most pulling trucks it due to the substantial increase in timming. Isn't it rumored that Schied and other fellows are running timming upwards of 45 degrees? The lower compression ratios they run probably have something to do with that as well.
