big single for sledpullin?
Chris, there is no wastegate on a A5k. Whatever you fuel it to, it spins. That is the one downfall to it. With stock injectors you should only be able to get it to about 55 lbs though and you should be fine with stock bolts. Tim
I'll go against the grain and say that studs are not mandatory on a common rail engine with an Aurora 5000.
A friend of mine runs his Aurora 5000 @ about 60psi down the track pulling the sled and still is on his stock gasket and stock bolts. He has had the Aurora on for about 15 hooks or so (all of last year) (600+hp too).
Those common rail head gaskets are alot tuffer then what come on the 12&24valve engines, and even factory stock engines make 30+psi on CR, so the new gaskets are made to hold alot more.
Once you get to pulling some you'll know what I mean.
Some tracks will load and unload your truck depending on your combination and can snuff a turbo in a millisecond.
turboost
09-19-2004 07:24 PM
